fuel pump removal - 1964 dynamic
Old July 6th, 2008, 08:16 AM
1964 dynamatic rag
Jody Karls's Avatar
OK guys (& gals) any tricks to getting the fuel pump out of a 1964 olds dynamic converetable? That back nut seems almost impossible to remove - or replace for that matter. Also, are these pumps avaliable? Can they be rebuilt? Wherehave you guys foind parts for this?
Jody
Jody Karls is offline
Old July 6th, 2008, 09:46 AM
I find parts for my 1964 Olds 98 at Kanter or Fusick.
http://www.fusick.com/
http://www.kanter.com/
Olds64 is online now
Old July 6th, 2008, 10:12 AM
1964 dynamatic rag
Jody Karls's Avatar
Thanks -this site is a great resource
Old July 6th, 2008, 01:07 PM
marinus_'s Avatar
I have a brand new fuel pump which i purchased by mistake for my 64 starfire. I was told that it was for a 64 dynamic 88 and i thought it might be the same as mine but it wasn't. The only number that i can find on it is M9785.
Does this look like the one?
File Type: gif
File Type: gif
marinus_ is offline
Old July 6th, 2008, 03:52 PM
Oldsdruid
rocketraider's Avatar
You need a short socket and a wobble extension, a good light and a steady hand to R&R that back bolt. The pumps can be rebuilt (designed for it BTW) but do NOT get an older rebuild or an NOS, or you'll be pulling it back off in a very few miles. Modern gas destroys the old diaphram materials quickly. Make sure the pump was rebuilt using materials compatible with modern fuels.
Rebuilding one is no big deal and can be done with ordinary hand tools. Modern fuel compatible rebuild kits show up on ebay all the time, or there's people who do it. I always suggest purchase of a factory shop manual if you intend to do any work on your car yourself.
Marinus, your pump looks like a Pontiac pump. All 1963-64 394 pumps are identical except A/C car pumps have a return line that is plugged on non-A/C applications.
rocketraider is offline
Old July 6th, 2008, 03:57 PM
I have about 3 fuel pumps for my car. All of which don't work. I imagine they need to be rebuilt. Instead of buying one from Fusick or rebuilding it I just put an electric fuel pump in. Much more dependable, but a good mechanical pump works well too.
You know, that doesn't look like my pumps either. The ones I have all have a small sight glass or fuel filter built into the side.
Old July 6th, 2008, 05:24 PM
marinus_'s Avatar
Anybody need a pontiac fuel pump? cheap.......
marinus_ is offline
Old July 7th, 2008, 08:28 AM
1964 dynamatic rag
Jody Karls's Avatar
fuel pump
Yes - that is not the pump. Mine has the site glass attached to it. Thanks guys for all of the input. I like the idea of an electric pump. I had even thaught obout doing that. ANyone have ideas on what kind, make, size ect.. of electric pump?
Jody
Old July 7th, 2008, 09:00 AM
71'OldsCutty
southcarolina803's Avatar
if you want to spend a little bit of money heres the one i am getting. i think.
http://store.summitracing.com/partde...%2D150&FROM=MG
southcarolina803 is offline
Old July 7th, 2008, 09:10 AM
1964 dynamatic rag
Jody Karls's Avatar
fuel pump
The numbers on my pump are = AC Delco 6893
Anyone know the specs on this so I can buy an appropreate electric replacement?
jody
Old July 7th, 2008, 07:00 PM
I am not sure what electric fuel pump I used. I do know it was an auto parts store cheapie. IT is definitely 100% pure CHINESIUM!
Old July 8th, 2008, 05:19 AM
1964 dynamatic rag
Jody Karls's Avatar
yah, I just talked to a guy at the parts store and apparently unless your going for performance it really doeasn't matter what pump you use. Thanks guys for the input, I'm going with the electric pump and forget about that back bolt on the original pump.
Old July 8th, 2008, 07:23 AM
1964 dynamatic rag
Jody Karls's Avatar
Here is the actual pump
File Type: doc
Old July 8th, 2008, 05:02 PM
Sooth! That is the original pump!
eddieunderground
February 4th, 2014 12:57 AM
Nor Cal Andy
March 29th, 2012 07:27 PM
1964starfire
January 3rd, 2011 04:05 PM
sshriber
March 22nd, 2010 06:16 PM
mikeraines63
July 4th, 2008 03:23 PM
Quick Reply: fuel pump removal - 1964 dynamic
