1964 Fuel Pump
Old April 23rd, 2014, 01:34 PM
Wedgewood Rod Shop's Avatar
1964 Fuel Pump
Can anyone tell me how I can replace the fuel pump on my 1964 Olds 98? it is a 394. I don't believe they reman a direct replacement, but would a chevy pump work?
Wedgewood Rod Shop is offline
Old April 23rd, 2014, 01:50 PM
Oldsdruid
rocketraider's Avatar
Chevy pump drives from a pushrod. Olds uses a lever that contacts the cam eccentric.
You should be able to find a rebuild kit for that pump ez enough. That or make a blank-off plate and run a low-pressure electric pump. If you rebuild, get a kit compatible with crap ethanol gasoline.
rocketraider is offline
Old April 23rd, 2014, 01:51 PM
Oldskeeper's Avatar
64 and 63 are the same pump and you can get the rebuild kit for it that updates it for the new gas. I picked up a kit off e bay and it worked out fine. Fusick also carries these pumps if I remember correctly, they should have one at Carlisle this week
Steve
Oldskeeper is offline
Old April 24th, 2014, 06:21 AM
Great, thanks everyone for all of the info and advice.
Nor Cal Andy
March 29th, 2012 07:27 PM
1964starfire
January 26th, 2011 03:22 PM
1964starfire
January 3rd, 2011 04:05 PM
sshriber
March 22nd, 2010 06:16 PM
Jody Karls
July 8th, 2008 05:02 PM
Quick Reply: 1964 Fuel Pump
