Four core or equivalent sized radiator recommendations.
Old March 28th, 2014, 07:41 PM
ttg
ttg's Avatar
Looking for a manufacturer recommendation for a four core or equivalent radiator. Must be direct fit preferably OE looking. Engine is 408ci J&S with a mild cam. Street cruiser, not a racer. Manual Transmission and AC. Budget is around 500.00 but less than that is preferred. Any assistance y'all can provide is greatly appreciated.
ttg is offline
Old March 28th, 2014, 08:49 PM
2blu442's Avatar
There's numerous aluminum radiators out there that would fit and function well. But if you wanted it to look original you might get a Harrison 4 row and have it re-cored. Do you already have the 4 row top plate and bottom saddles? If you go with a factory one you'll need that. If you go aftermarket you may find something that will cool well enough and fit under the three row top plate. Surf ebay for aftermarket. Or try the search option for aluminum radiator.
Here's one that may or may not still be available, worth checking out if you want to go that way.
https://classicoldsmobile.com/forums...-radiator.html
2blu442 is offline
Old March 30th, 2014, 09:11 AM
One of the fellas in the local Olds Club has a large aluminum radiator that has 4 row sized end tanks and fits in with the 4 row saddles. It's painted black and from all outward appearances looks "original".
Another option is what I have - a high efficiency 4 row core installed on the factory 3 row end tanks. Fits perfectly and cools very well. It's a Craig 858384 High Efficiency core that the radiator shop said was available as a core only and not as a complete radiator.
Fun71 is online now
Old March 30th, 2014, 10:29 AM
Stevec's Avatar
I still have that radiator let me know if your interested I'll givee you a good deal...
Stevec is offline
Old March 30th, 2014, 03:10 PM
jag1886's Avatar
I got a brand new 4 core for my 65 from US radiator. It was a perfect copy of the original it was just a a little more than your budget but they are nice.
jag1886 is offline
Mak
May 5th, 2016 05:57 AM
ramairthree
June 23rd, 2013 07:37 PM
tcarroll
December 26th, 2012 11:48 AM
60193W30
November 4th, 2012 05:41 PM
tcarroll
September 17th, 2012 09:22 AM
Quick Reply: Four core or equivalent sized radiator recommendations.
