Dyna Mat (or equivalent), School Me
So, I'm getting ready to install new carpet. While I have the interior gutted I'm replacing a window motor, replacing the power top pump and a few other items. My car is pretty quiet, and what noise there is because it's a convertible, so I had decided not to use dyna mat. After thinking about, when will I ever have the interior gutted again? I guess I should. I'm considering a knock-off product to save some bucks... looking at this stuff: http://www.ebay.com/itm/FatMat-50-Sq...ce3df0&vxp=mtr
I'm assuming 50 sq ft should be enough? Any tips from those of you that have installed it? Anything else I should consider before I start? Thanks in advance.
go to the lumber yard and get a roll of frost guard.this is used for shallow pitched roofs to keep ice from permeating up under the bottom rows of shingles.3ft wide by maybe 60ft long.it's basically dynamat at half the price.
Interesting. 3' wide roll sounds a lot easier to install than 18". Have you used it? Does it put off any odor?
Really happy with the Fatmat. Just make sure the surface is very dry.
Be a little careful of the hardware store stuff. Some can vent off unpleasant odors. You don't want to smell like a freshly paved road after every drive.
Nope, none at all.
See post 71 from my build thread:
https://classicoldsmobile.com/forums...ii-swap-2.html
I used mobile home roof repair. Possibly the same stuff. It's a 1ft by 15ft roll for $15 or something at Home Depot. Haven't found it at lowes. But no odor after installation on 3 vehicles. Easy to manage and adhere and does the trick.
Ya know, I was kinda looking at the hardware store stuff to save a few bucks too. And I have no doubt others have used it successfully. But I doubt there are specifications for roof materials with respect to odor. So even if it worked well the last time, that's no guarantee it will the next time.
And after laying the fatmat down, I suspect any adhesive product would be a major mess to remove. And that wouldn't include stripping out the entire interior.
Your choice, but that's one job I would spend the extra on a product made for the application if there's even the most remote possibility of the cheaper stuff would cause issues.
seam sealer or over it
Nope, none at all.
I just cleaned off anything loose, laid down some por15, and put down the fatmat.
I did learn ANY moisture on the metal definitely affected adhesion. In my case it was a propane heater causing condensation in the winter.
I also discovered if you heat the fatmat to about 150 degrees in the oven, it was more pliable and REALLY stuck well.
I honestly don't remember how much I bought, but 50 sounds about right. That was just enough to do firewall, floor, and doors. I did not do the roof. Take a look at yours. Mine had a fairly dense insulation stuck there already. It looked like a major mess to remove and attach fatmat to the metal.
Mine is a 65 and it had a tar like stuff with card board and insulation on top of that
There was a huge dent on one side of the roof that I worked out and as I was heat shrinking the metal that tar like stuff cought fire, so most has been removed but yeah it's a pita
I have no odor from the fatmat. As a contractor, I would NOT use the roofing materials mentioned. They are not designed for heat from underneath for one. Exhaust? They are made to seal nails and shingles from ice backup. I would rather stick to the designed application. As far as the mobile home roof stuff, I don't use box stores. JMO.
Now I'm down to ordering either
Fatmat: http://www.ebay.com/itm/FatMat-50-Sq...mtr&rmvSB=true
Or GTMat: http://www.ebay.com/itm/121069527339...%3AMEBIDX%3AIT
This is what I was looking at today
http://www.amazon.com/gp/aw/d/B003TU...eywords=fatmat
It's thicker
I
It's thicker
I
By my measurements (which are probably wrong), it looks like 50 sq' isn't even quite enough to do just the entire floor (5.5' wide by 9' long)?
Check out this thread:
https://classicoldsmobile.com/forums...on-primer.html
I ordered GTMat last night (cuz I'm cheap ) http://www.ebay.com/itm/110913365568...%3AMEBIDX%3AIT
Hopefully it will be adequate for my needs (my car is just a daily driver, not a full restoration project).
Thanks again, that really helps!
Hey Mak, I know it's only been a couple of months but I was wondering how you like the GTmat. Looks like the best deal out there for a non-asphalt based deadener. Did it smell and was 75 sq ft enough?
#31
I really wish I could answer those questions, but I can't because it's still sitting in the garage next to the carpet kit, waiting to be installed! I got tied up fixing the power top & dealing with exhaust manifold leaks. The good news is, those problems are fixed... and I'm planning on pulling the front seat out and starting the carpet job first thing next Saturday morning!
#32
Mac, I got the fat mat 80mil. I currently have the roof done and head liner almost in its been a week no Oder, I did check out the hard ware store stuff. I was thinking of using it to fill in the gaps, but after feeling and smelling it is different stuff and it does have a strong asphalt smell if it stays? I don't know, didn't want to chance it .
It was easy to install I had my 4 &9 year old helping
I have over half left of the 50sq. I think this would have done the floor pretty easy depending, on how far up the fire wall you go
Going to order another 50 to do the floor. I will check back in how much extra I have. I want to do the rear quarters in the trunk with the stuff if I have enough extra
#33
The 80 mil is a little pricey for me but IIRC it's non-asphalt. I'm not so sure about the 50 mil. I think that one is asphalt. I did find this and asked for a free sample.
http://www.ebay.com/itm/371247777469...%3AMEBIDX%3AIT
Sorry Mak, didn't mean to rush you, lol. I know what it's like (as many of us do) having boxes laying around with awesome stuff in them that you just can't find the time to deal with.
#35
This begs the question; what are the most important spots to cover? Honestly, I hadn't thought about the ceiling. Is it important? I'm trying to hush my exhaust as much as possible. I can't hear the stereo very well. So I was thinking floor, behind back seat, under the package tray, and both doors. And speaking of doors; some folks cover the the inside skin, others behind the door panels, and yet some do both. I might be adding speakers to my doors and so should do something there.
Randy, I know $140 isn't much but after the new carpet, seat covers, and headliner (not to mention needing about 10 more cans of the Duplicolor), any more and we won't be hitting the road this summer, ya know? Was your $140 Fatmat the 50 mil and was it asphalt based? Mary has asthma and the asphalt would be b.a.d.
#37
#40
Boy, what a difference it made in the ride quality... Much quieter & more solid feeling now, it literally feels like a different car!
