Factory Correct Heater Hoses - 70 Cutlass
Old October 7th, 2010, 06:24 AM
Del70's Avatar
I would like to replace the heater hoses on my 70 Cutlass, with factory correct hoses. Of the parts suppliers I have looked at some describe their product as having the correct ribbed hose, but no pictures. I have seen some low mile cars and pictures of some that have smooth hoses, but there are very slight ribs running perpendicular to the hose wall, which gives then a slight bumpy ribbed appearance. I have also seen some cars (personally looked at 50K Cutlass that I think had a few of its factory hoses) that had hoses with a 1/4 wide band made up of several ~1/6" height small raised ribs that ran the length of the hose. What should a factory correct heater hose look like?..
Del70 is offline
Old October 7th, 2010, 10:06 AM
I have no idea what a factory heater hose looks like but Fusicks might carry what you need.
http://www.fusick.com/
Olds64 is online now
Old October 7th, 2010, 11:04 AM
Lance
ROCKET VAPOR's Avatar
I get my factory type ribbed hoses from Jeff Ashten at http://www.broachbuster.com/
I wish he would start hand stamping radiator hoses for Oldsmobiles.
ROCKET VAPOR is offline
Old October 8th, 2010, 03:39 AM
Del70's Avatar
thanks Rocket Vapor - it is hard to tell from the pic on the link - are ribs cut on the hoses you bought , cut into the hose or are they raised molded into the hose. The picture looks like they are cut into the hose. thanks..
Del70 is offline
Old October 8th, 2010, 05:22 AM
Lance
They are grooves molded into the skin of the heater hoses as per original.
I have been told that the number of the ribs and the spacing of the ribs on the heater hoses are to identify them, some sort of classification.
I believe his heater hoses are made by Gates and his radiator hoses are made by GoodYear, quality stuff for sure.
Old October 8th, 2010, 09:21 AM
Del70's Avatar
More on the Heater hose subject..I found a picture I took of a ribbed hose on that low miles Cutlass. Picture shows a ribbed heater hose with 1572 EDMP stapped in white on it. I have seen this EDPM stamping on other heater hoses before., orrigianl cars... Is this a factory hose/marking?...
Del70 is offline
cutlass47
March 30th, 2017 09:41 AM
Del70
June 7th, 2010 02:46 PM
ROCKET VAPOR
May 7th, 2010 06:41 AM
Texas442
November 27th, 2009 05:01 PM
65cutty
June 12th, 2009 06:45 AM
Quick Reply: Factory Correct Heater Hoses - 70 Cutlass
