radiator & heater hoses
being I dont have the car near by so as I cant measure the upper and lower radiator hose size. is the upper is 1 1/2 inch both ends? and the lower also 1 1/2 both ends and are both heater hoses 3/4 or 5/8 ? its a olds 350 1975 no air just heat thank you.......jim
Best bet is to measure both radiator connecting points as well as the thermostat housing and water pump inlet with a vernier caliper. Most applications are 1-1/2" both ends on upper radiator hose and the same with lower, but some show to have 1-3/4" on one end whether upper or lower.
Heater hoses are 1/2" in, 3/4" out except for an apparently oddball arrangement which had .63 both in and out. Check engine, pump, and core nipples with vernier caliper for correct size just to make sure.
Norm
Texas442
November 27th, 2009 05:01 PM
