1500A-4000A jump packs vs. SBO/BBO?
Old November 19th, 2021, 06:20 AM
I thought there was already a thread on our site about these but I can't find it.
Will these battery jump packs work to start our classic Oldsmobiles?
Amazon Amazon
The answer is NO!
I bought one of these a few months ago and tested it on my 96 98. It started effortlessly after leaving the headlights on all night. This weekend I tired to use it on my 71 98 because the battery was dead. It only allowed the starter to crank for 3-4 seconds before being completely drained. This was barely enough time for the fuel pump to fill the carburetor.
Classic car owners beware!
Olds64 is online now
Old November 19th, 2021, 10:37 AM
allyolds68's Avatar
This Jump Pack has never let me down. I use it all the time on all my stuff including the 455. Its much smaller than the one you posted
Amazon Amazon
allyolds68 is offline
Old November 19th, 2021, 10:53 AM
Gary
VC455's Avatar
The one you purchased lists that it starts engines up to 7 liters. Your 455 is 7.5 liters.
The sellers have incentive to fudge the jump-starter's UP TO rating, so I get one size larger than their claimed UP TO.
VC455 is online now
Old November 19th, 2021, 12:27 PM
I fixed the link. The jump pack I bought was rated for a 10L diesel engine and "ALL' gasoline engines.
Let me tell you, there's NO WAY one of these jump packs could work on my 6.9L IDI in my Ford truck. At 22.5:1 compression the jump pack would drain the moment you hit the key.
These jump packs might be fine for daily drivers but buyer beware.
Old November 19th, 2021, 12:58 PM
Gary
VC455's Avatar
That one should have worked on your 455 without any problem.
The performance is disappointing based on the claims. By the manufacturer's name, perhaps it is made of Chinesium.
I got this US-made one years ago for my 455: https://no.co/media/nocodownloads/fo..._5.13.2020.pdf
It has worked well and I only need to charge it every few years if I don't use it.
The weight is 6 pounds, a lot for a lithium jump starter, and by their measure it would be marginal to start your truck.
edit: When I checked, I found that current GB150s are made in China.
Last edited by VC455; November 19th, 2021 at 01:17 PM. Reason: added information about country-of-manufacture
VC455 is online now
Old November 19th, 2021, 01:33 PM
When was the last time you charged it? They need to be recharged regularly to work effectively.
oldcutlass is offline
Old November 19th, 2021, 06:33 PM
The answer is NO! .
My ‘71 Supreme is a DD.
Fun71 is offline
Old November 19th, 2021, 07:04 PM
Vincit qui se vincit
vCode442's Avatar
Recently picked this one up on Amazon for about 80 bucks, rated at 2500A. It (all jump packs) must (should) have a full charge, and has worked for me, each time, fully charged - haven’t tried it at a lessor charge.
Thought I had the somewhat ubiquitous ‘hot starter’ issue, but if a jump pack will get my ‘71 455 going, it’s most likely a battery /wiring issue, exacerbated by heat.
vCode442 is online now
Old November 19th, 2021, 07:25 PM
bccan's Avatar
I have come across and owned a number of these starters for about ten years, since I first became aware of them. Before I bought the first one, with pure skepticism, I took it out to dead diesel pickup in the lot and it worked, sale made. I bought others for the family as gifts, they were all similar in size though not appearance to the original post. They all worked well for a couple/few years and then stopped being viable to jump start and then even lost their ability to charge electronic devices.
The best, most powerful and most reliable boxes in my experience have been the “NOCO” models, all of which still work after 5+ years. To be fair the 2 NOCOs are a medium size and a heavy diesel “rated” box at 1000 & 2000 amps respectively.
The model mentioned in OP, as a new unit, should have been sufficient to start that engine. It is defective or deceptive, probably both.
bccan is offline
Old November 20th, 2021, 06:13 AM
fleming442's Avatar
No jump box will overcome a bad battery. Let's be realistic. If the car is at your house, there's no reason to have a jump box over a real charger. Don't rely on the alternator to provide a deep charge unless you're taking a very long drive, using minimal accessories (lights, wipers, etc).
fleming442 is offline
Old November 20th, 2021, 06:26 AM
Gary
VC455's Avatar
If the car is at your house, there's no reason to have a jump box over a real charger... Don't rely on the alternator to provide a deep charge...
YES. Many do not understand that leaving a wet battery partially-charged shortens battery life dramatically.
VC455 is online now
Old November 20th, 2021, 10:39 AM
vCode442's Avatar
Trickle charge + jump pack = peace of mind
Old November 20th, 2021, 10:03 PM
OK, you seem to have More Than A Feeling about this.
https://m.youtube.com/watch?v=t4QK8RxCAwo
Fun71 is offline
Old November 21st, 2021, 02:50 AM
fleming442's Avatar
So, how did you find out the jump box wasn't enough to start the car? 🤔
Old November 21st, 2021, 07:08 AM
72 Olds CS
RetroRanger's Avatar
https://youtu.be/edwk-8KJ1Js
well it was not a very “Long time” before your response.
RetroRanger is offline
Old November 21st, 2021, 07:59 AM
vCode442's Avatar
If you don’t have a well charged battery or jumper pack, you might need to hitch a ride
Old November 21st, 2021, 04:04 PM
72 Olds CS
https://youtu.be/jamMWsZ3yvE
thatll be fine. As long as the driver is a “Smokin” blonde
Old November 21st, 2021, 04:28 PM
vCode442's Avatar
Ha! And if you’re lucky, maybe she’ll say: there’s something about you
and...let me take you home tonight
(Sorry for the hijack, but this is kinda fun)
Old November 23rd, 2021, 12:15 PM
When I tried to jump my 71 last weekend the jump starter had been charged as recently as a month ago. I just bought it and fully charged it after I tested it on my 96 98..
I imagine the jump starter failed to start my 71 because the carburetor fuel bowl was completely empty when I tried to start it. By the time there was fuel in the carburetor and I could depress the accelerator to set the choke the jump starter was drained.
I'd be interested to know what kind of diesel Bccan jumped with his jump starter. Probably a Duramax or a Cummins...
Old November 23rd, 2021, 12:35 PM
72Cutlass S
gs72's Avatar
When I first read the title of this thread several days ago, this is the first thing that popped into my mind. 😂
gs72 is online now
Old November 23rd, 2021, 01:44 PM
bccan's Avatar
How’d you guess? It was indeed one of the big 3, I’m going with Ford or Duramax but it was pushing 10 years ago so I don’t really remember. What I do remember was being amazed that such a little box pulled that off. I think that was the only diesel I ever jumped with a little box, we always had the basic battery style jump box, much bigger & heavier but they proved to work reliably far longer than the capacitor boxes I’ve seen. To be fair, maybe they last longer nowadays with evolution and proliferation on their side. I have one cheapie that I think still works and the 2 NOCOs that are really nice and still going after 5 years or so. I rarely need them, iirc the last time one got the call was to rescue someone at a drive in movie that overextended their battery. Time will tell, it always does!
bccan is offline
Old November 23rd, 2021, 03:33 PM
solly's Avatar
jump starters
Here's my two cents,
About 5 years ago I had a 1990 box Cherokee it was my off road rig it sat behind my RV gate about 6 months out of the year (if you know AZ you know it's to damn hot to 4 wheel in the summer) every year at the beginning of 4x4 season the Cherokee would be deader than Kelseys ***** !! I have a Schumacher battery charger but it always seems to spend more time at my neighbors or son-in-laws house so I ordered a compact lithium jump pack from Amazon it was rated for up to 6.0 diesel it was a Gooloo brand (never heard of them) highly reviewed and highly rated so I took a chance, I was very skeptical, when it arrived I was pleasantly surprised nice case, nice clamps, nice rugged housing
much better than I expected but as they say the proof is in the pudding I figured that Cherokee would be the ultimate test . Prior to receiving the jump starter I would usually have to jump it off one of my other vehicles this usually required at least 20 minutes or longer of running time,
I hooked that jump starter up to the Cherokee and it cranked like there was 2 battery's hooked up !!! You know those old Cherokee's with a gear reduction starter are known for long crank times !! no problem for this little jump starter .
Prior to getting my maint./battery tender for my 56 Olds I went to exercise my Olds and was met with a dead battery, While my Olds only has a displacement of 324 cid I had to use that jump starter several times and it started the old girl with no problem !! I also have used it to rescue several people, those things are life savers !!! I own 3 vehicles and plan to have one in the trunk of all.
P/S it was last Charged about 7 months ago and still shows 96% charge. I'm sure if folks pay attention and purchase one with the proper specs for their vehicle they will be pleasantly surprised.
solly is offline
Old November 24th, 2021, 04:25 AM
That's good that folks have had a positive experience. I'll keep the jump starter in the trunk of my 96 98 and remember to charge it periodically.
Here's the YouTube video I watched before I bought the jump starter:
Old November 24th, 2021, 09:40 AM
BackInTheGame's Avatar
I like the Project Farm videos, also. Great job of real world comparisons on many and varied product categories. Though I must say I'm surprised the GP4000 didn't work out in your situation, given the ranking PF gave it.
BackInTheGame is offline
Old November 26th, 2021, 08:56 AM
bccan's Avatar
Liked the impressive arc jumping between A/C pulley and cruise unit over on the driver side of engine when he tests the first Gooloo in the truck. ~9:38 in the vid.
bccan is offline
solly
November 23rd, 2021 09:25 AM
matt69olds
May 30th, 2021 08:35 AM
chip-powell
September 8th, 2015 02:13 PM
auto_editor
March 26th, 2015 09:20 AM
roberer
December 19th, 2014 06:40 PM
Quick Reply: 1500A-4000A jump packs vs. SBO/BBO?
