Convertible hood without motor close?
Old March 26th, 2013, 12:55 PM
Oldsmaddin's Avatar
Hi, I have a question.
Can you the convertible hood without motor close?
How to do it?
1968 Delta 88
Greeting Martin
Oldsmaddin is offline
Old March 26th, 2013, 01:02 PM
starfire's Avatar
Yes you can. Get a friend to help you (you can do it by yourself, but it's a lot easier with two). Stand in the back seat, grab ahold of the front of the top, and very slowly pull upwards and toward you. It will move up. Keep slowly and evenly pulling it towards the front of the car.
starfire is offline
Old March 26th, 2013, 01:03 PM
Yes.
Disconnect the hydraulic cylinders on either side of the back seat, then you will be able to move the top by hand.
Watch out, though, it will be heavy.
When these cars were made with non-power tops, they used a large spring on each side in place of the hydraulic cylinders to help with the weight.
MDchanic is offline
Old March 27th, 2013, 11:10 AM
Oldsmaddin's Avatar
Thank you very much. With the tip slowly up move has worked.
Two people have submitted.
Greeting Martin
Old March 27th, 2013, 11:37 AM
starfire's Avatar
Eric, the hydraulic cylinders should not need to be disconnected. If you were going to manually open and close it many times then I agree, but he should be able to close it once with the cylinders connected without any issues.
starfire is offline
Old March 28th, 2013, 03:45 AM
Originally Posted by starfire
... he should be able to close it once with the cylinders connected without any issues.
I thought that was what he did want.
Glad you got it down, Martin!
(Or should I say, "Glad you it down got"? - German word order confuses us English speakers.)
MDchanic is offline
Old March 28th, 2013, 02:33 PM
Oldsmaddin's Avatar
Hehee, so do we also with English... Google Translator helps but quite well
Bye, Martin
WTony
March 18th, 2014 12:27 PM
69ishHoliday
Body work
November 19th, 2013 06:05 AM
Aceshigh
September 29th, 2010 10:31 PM
Nilsson
September 12th, 2009 03:26 PM
f-85
January 11th, 2009 09:31 AM
Quick Reply: Convertible hood without motor close?
