'63 slim jim 10 speedo connection
Old January 31st, 2017, 05:06 PM
psax42's Avatar
swapped out my slim jim with a replacement - my speedo cable runs to the front wheel. This tranny is set up for a speed cable to the housing. I need a way to plug the hole for the speedometer cable in the transmission housing. Any ideas? THe hole mics at .984 inches. THanks
psax42 is offline
Old February 1st, 2017, 05:29 AM
I used to have a 64 Olds 98 with the same setup but it was such a long time ago I can't recall the specifics. Is it a speedometer cable similar to this one?
https://www.amazon.com/ATP-Automotiv...edometer+cable
If so, you should be able to get a threaded cap at your local hardware store or online. Just figure out the size and thread pitch of the connector and your golden. BTW, pics would help.
Olds64 is offline
Old February 1st, 2017, 08:17 AM
psax42's Avatar
It is smooth with a clip on the top. There is a hole to bolt in the cable but the connector is not threaded. I am going to try a 25mm rubber expansion plug from Dorman
psax42 is offline
Old February 1st, 2017, 10:50 AM
Good luck.
Olds64 is offline
Old April 15th, 2017, 01:53 PM
psax42's Avatar
worked okay - thanks
psax42 is offline
GeneS12320
April 28th, 2008 06:39 AM
GeneS12320
September 28th, 2007 02:31 PM
RatRod
March 22nd, 2007 08:17 PM
bjtstarfire
Drivetrain/Differentials
December 6th, 2006 09:56 AM
Quick Reply: '63 slim jim 10 speedo connection
