Where do these wiring harnesses connect on a 92 olds cutlass supreme S
So I just bought this car and on top of the catalytic converter sounding clogged up
I found these two wire harnesses that are disconnected right next to the fuse box that has the ABS relay right next to the battery
A seriously big WTF, also I noticed it looked like the battery had leaked and got a mess of white gunk on the engine bay, seriously kinda regret buying this because I don't know where to continue now, should I replace the Resivoir, is there a modification to fit the Resivoir in a different spot?
What about throwing an air intake kit? That could save some space? In the engine bay
So where the hell does this grey one go then??
So I have found out that the grey little connector has another wire that leads straight to the fuse box, one red wire that has the connector on there and the other is a black wire that leads to a solder joint next to the positive terminal on the fuse block
jason0820
March 6th, 2013 07:20 PM
