Where do these wiring harnesses connect on a 92 olds cutlass supreme S
Old April 15th, 2022, 01:46 PM
Bjankins1's Avatar
So I just bought this car and on top of the catalytic converter sounding clogged up
I found these two wire harnesses that are disconnected right next to the fuse box that has the ABS relay right next to the battery
Bjankins1 is offline
Old April 15th, 2022, 02:10 PM
Phoenix8990's Avatar
More of a pice would help. Possibly the windshield washer pump?
Phoenix8990 is offline
Old April 15th, 2022, 02:38 PM
Bjankins1's Avatar
Yea I can get a better pic when I head outside but the previous owner did say something about not using the windshield washer, god knows why
Old April 15th, 2022, 03:19 PM
Bjankins1's Avatar
So here's a few photos
Old April 16th, 2022, 01:15 AM
Bjankins1's Avatar
It's the two hanging wires next to the cruise control servo
Old April 16th, 2022, 05:14 AM
I hada 94 a while back and don't clearly recall but I think the ww fluid tank is in that corner. Have you checked to see if it is connected or there are wires hanging?
Steve
Old April 16th, 2022, 05:05 PM
Bjankins1's Avatar
Steve
Lmao guess what I found out? The pump and the Resivoir for the wiper fluid is completely missing and the battery is where the Resivoir should be, so I'm guessing those two wire go to the pump
A seriously big WTF, also I noticed it looked like the battery had leaked and got a mess of white gunk on the engine bay, seriously kinda regret buying this because I don't know where to continue now, should I replace the Resivoir, is there a modification to fit the Resivoir in a different spot?
​​​​​​What about throwing an air intake kit? That could save some space? In the engine bay
Old April 17th, 2022, 06:04 AM
I think the resevoir is kind of tucked in lower than the battery behind the bumper. I would think you should be able to find one for it or from another car that would work.
Steve
Old May 9th, 2022, 01:57 PM
Bjankins1's Avatar
Steve
So I have found out that the grey little connector has another wire that leads straight to the fuse box, one red wire that has the connector on there and the other is a black wire that leads to a solder joint next to the positive terminal on the fuse block
So where the hell does this grey one go then??
Old May 10th, 2022, 12:01 AM
You may want to consider buying a factory Chassis Service Manual and Electrical Troubleshooting Manual, which have the wiring diagrams.
joe_padavano is offline
RUSTYCUTLASS70
May 29th, 2021 06:21 AM
cmpcpro
June 18th, 2017 03:21 PM
DreamSupreme71
August 4th, 2013 10:49 AM
jason0820
March 6th, 2013 07:20 PM
pinky
February 19th, 2011 07:45 PM
Quick Reply: Where do these wiring harnesses connect on a 92 olds cutlass supreme S
