Energy susp. body mount bushings
Old June 8th, 2014, 11:57 AM
Chevy budget Olds powered
coppercutlass's Avatar
Guys im looking for anyone with experience using this kit from energy. I assembled the bushings as per the instructions. I also used my old bushings as reference. My issue is today I went to go pry up on the body from the frame and I have vertical movement. is this normal ? Did I not tighten it enough with my impact gun ? I installed the washer sleeve up top how my factory bushings where then I used the big washer and the little bushing underneath but when I tightened it up it just squeezed out. I cant imagine this movement being normal but this is also my first time doing body bushings so go figure lol. I was thinking of cutting up some pipe into .5 sections incase the bolt wasn't squishing the bushing enough so I could get more positive compression from the bushing . This is all new to me but I still have time to address this since the car is still apart.
coppercutlass is offline
brownbomber77
June 11th, 2018 05:39 AM
Octania
July 12th, 2016 09:59 AM
RandyS
June 10th, 2013 09:35 PM
Lars
Suspension & Handling
April 21st, 2013 08:26 PM
66trifire
April 12th, 2009 08:50 AM
Quick Reply: Energy susp. body mount bushings
