Broken body mount bolt
Old October 12th, 2020, 09:55 PM
tkcutlass's Avatar
Any suggestions on removing the broken bolt in the body mount or removing/replacing the nut shown in the picture
tkcutlass is online now
Old October 12th, 2020, 10:23 PM
Is there enough shank left to lift the body, remove the rubber mount, and grip it with vice grips?
oldcutlass is offline
Old October 13th, 2020, 04:11 AM
72455's Avatar
Drill it out and re tap it.
72455 is offline
Old October 13th, 2020, 05:52 AM
rob1960's Avatar
The front body mount at the cowl torque box is just a bolt with a loose nut, some used a square nut(like yours) others used a flanged hex nut( depending on the assembly plant or year built). Try to get a wrench in there to hold it . Inline & others sell the bolt kit for the front mount. It's the easiest one to do since you can get to the nut. Any other body bolts on the car( they vary from car to car) like the 4 under the trunk have cage nuts spot-welded inside the floor braces. If you break one of those you'll have to cut a hole in the floor pan to get to the nut( a hole saw or small cut off wheel work well) I changed all the body mounts on my '68 a couple years ago. I was dreading it but I really lucked out as they all unbolted! It took me longer to realign the bumpers than to change the mounts!
rob1960 is offline
Old October 13th, 2020, 06:00 AM
allyolds68's Avatar
You should be able to get a punch on the underside and drive it out the top. Judging by the crust around the body mount bushing I'm going to bet the mount location on the frame needs work
allyolds68 is offline
Old November 8th, 2020, 12:43 PM
maddoctor's Avatar
Try using a hack saw blade between the rubber and the frame. I assume you are going to replace the mounts and bolts anyway.
maddoctor is offline
Old November 8th, 2020, 04:39 PM
The nut in that location isn’t a captured nut. Use a Sawzall to cut the bolt in half , the top half will come out thru the top, the bottom will hopefully fall out.
matt69olds is offline
78Cutlass4Speed
May 9th, 2020 07:35 AM
1968_Post
September 12th, 2014 07:32 PM
Sampson
January 30th, 2014 06:42 PM
71cutlass350
January 7th, 2014 12:34 PM
Daniel Marsh
December 4th, 2013 06:48 PM
Quick Reply: Broken body mount bolt
