Painting my Frame?
Old January 25th, 2010, 07:50 PM
Wilson05's Avatar
Painting my Frame?
So after trying out the POR-15 and thinking about it tonight, I decided not to go with the POR-15. Well, for now anyway. Decided, it being such a permanent coating I will just paint the exposed portion of my frame, being the front of the car, from the engine fire wall forward with something else. Eventually I want to do an off-body restoration, 5-7 years down the road and would like to powder coat or POR-15 the entire frame at that time.
So where am I getting with all this mumbo jumbo? Well any suggestions on a paint or coating to but on my frame for now. Would prefer a paint I can roll on or put on with a brush. I do not want to spray anything as it is in my garage and don't want to get spakle all over my engine or anything else. Something that will hopefully be sandblasted off when I do a full restoration.Suggestions? Much appreciated as always.
Wilson05 is offline
Old January 26th, 2010, 04:53 AM
IF you want something lest permanent than POR 15 you might consider Rust-O-Leum paint available at your local hardware store. I've used the Rust-O-Leum primer before when I did body repairs and it's durable and works great. I imagine it wouldn't be as permanent as POR 15.
Olds64 is offline
Old January 26th, 2010, 04:54 AM
69-72 olds owner
paul879's Avatar
Use sem 38104 works good for frames just did my frame works like por-15 is cheaper about 21.00 a QT
paul879 is offline
Old January 26th, 2010, 10:43 AM
Registered
Bluevista's Avatar
I would just go with a Rust-O-Leum type paint too if you're going to remove it.
It may lift and wrinkle if you use any lacquer type spray over it but that shouldn't be a problem.
That chassis stuff is expensive in quarts because you usually spray it, takes more brushing it.
I like the True Value XO Rust paints and primers my only self.
My car ain't got no rust so I ain't not should of gonna' be needing none of that there Pork-15.
Bluevista is offline
Old January 26th, 2010, 11:07 AM
We can fit that, I'll loan Sandy my Sawzall.
Jamesbo is offline
Old January 26th, 2010, 11:31 AM
Cutlass Lover
cutlassgal's Avatar
I know how to use one of those, too! Never used one on metal, though!
cutlassgal is offline
Old January 26th, 2010, 11:33 AM
Maybe you should get a plasma cutter
Jamesbo is offline
Old January 26th, 2010, 12:06 PM
Cutlass Lover
cutlassgal's Avatar
How about a burning table??
Old January 26th, 2010, 01:23 PM
BobsW32
Bobsw32's Avatar
I used Eastwoods Chassis black and looks correct and is easier to remove than POR-15
Bobsw32 is offline
johnsw-31
July 4th, 2013 09:22 AM
Harmon
February 5th, 2011 07:10 PM
Ranzan
March 27th, 2007 08:40 PM
DJMatthews
December 5th, 2006 01:28 PM
Quick Reply: Painting my Frame?
