Brake adjustment
I loosen the adjustment until I can get the drum over the shoes. Then I tighten the adjustment through the backing plate until the shoes drag on the drum. Finally, I loosen the adjustment just enough so the shoes don't drag.
I've never checked the CSM procedure. Just the way Oldsguy taught me.
I learned it from my dad, around the same time frame. We had just purchased my first car, a 67 Cutlass that my aunt previously owned, and we were going through all the safety items, wheel bearings, and a tune.
They still need to be adjusted to where they just barely rub. Relatively the same amount at all four corners.
Good point, I missed that. As with my 62, adjustment will be needed periodically. And as stated above, a slight drag is preferred.
slw0501
Brakes/Hydraulic Systems
October 12th, 2015 01:55 PM
