north east machine shop
anyone know of a good machine shop in the north east that can turn a crank and bore the end for the pilot bearing? or would it be cheaper or easier to find one. im located near albany ny so the closer the better.
thanks
thanks
BTR or OPP are the true Olds guys nearest to you. They have both done it many times.
E & G Machine in Wallingford, CT does some Olds work for "stickw31" but isn't much if any closer to you than Bill or Andy. You can always ship the crank if you are absolutely sure of your block & rods' integrity & measurements but I would personally supply it all to whoever does the work.
2blu442
April 20th, 2014 10:48 AM
rootney
August 13th, 2013 09:06 AM
