Intake crossover
Old November 4th, 2009, 05:07 AM
AZ442's Avatar
Intake crossover
Trying to put my car back together using the Felpro 1356 after 2 failed attempts with the turker tray gasket. Performer intake is not blocked on the crossover so I ordered the crossover plugs from Ebrock #2733. With the plugs installed won't the gasked just burn through or is this OK. Read a post where one guy cut a piece of the old tray and used to block the head. Won't this leak.
I'm lost.
Any tricks to installing the plugs so they won't rattle.
AZ442 is offline
Old November 4th, 2009, 05:40 AM
Eightupman's Avatar
I know of a particular engine builder that fills Chevy crossovers with Hi Temp RTV and a ball of aluminum foil pounded into the head. 13 second cars to boot.
He has no issues so I would think if the heat doesn't burn through that, a slather of RTV and a peice of the tray will have no issues. I've heard using the gasket is fine as well. The turkey trays USED to come with some crossover covers...optional use of course.
John
Eightupman is offline
Old November 4th, 2009, 05:43 AM
Past Administrator
Oldsguy's Avatar
I think there is a specific temperature resistant epoxy that can be used to hold the plugs tight and prevent them from rattling. Unfortunately I do not know where you can get it. I do not think the gasket would burn through if the plugs are installed.
Oldsguy is offline
Old November 4th, 2009, 05:52 AM
I installed my Mr. Gasket gasket as per the instructions with no plugs or "pieces" of turkey tray. I've never heard about the cross over burning through the gasket.
Olds64 is offline
Old November 4th, 2009, 02:17 PM
The Stickman's Avatar
I bought the crossover plugs from Jegs. They are metal not aluminum so I figured they belonged in the head vs the intake so that is where I put them. Just ground them down a bit to the point where I would only have to do some pounding. They fit like a charm. I won't ever have to worry about burn thru.
The Stickman is offline
Old November 5th, 2009, 06:10 AM
I got a set of those plugs with my intake manifold but decided against using them. I've also heard they can come loose and rattle.
Olds64 is offline
Old November 6th, 2009, 04:45 AM
AZ442's Avatar
Back together
We will see if this works, got it back together last night. Will try starting today with my fingers crossed.
AZ442 is offline
Old November 6th, 2009, 05:41 AM
Good luck. Keep us posted.
Olds64 is offline
Old November 6th, 2009, 07:53 AM
citcapp's Avatar
Looks sweet, post a video of it running. I love the sound of an Olds
citcapp is offline
Old November 9th, 2009, 01:33 PM
geckonz08's Avatar
I have only seen one set and they too were in the heads --Pretty sure that is where they are supposed to fit ?
Not thread stealing but does anyone know what hp may be gained ?? theoretically ?
mike
geckonz08 is offline
Old November 10th, 2009, 06:12 AM
AZ442's Avatar
I think this may have done it, drove about 60 miles and no leaks, sure seems to run better. (with wife had to drive my age)
I did install the plugs in the heads per the ebrock instructions sheet and filed progressive groves in the plugs for a better bite.
Thanks for all your help!
AZ442 is offline
Old November 10th, 2009, 09:17 PM
Eightupman's Avatar
mike
10-15 depending on what other upgrades you have done. But free horsepower is free horsepower.
John
RAMBOW
November 26th, 2011 03:55 PM
m455sx
November 2nd, 2011 06:40 AM
nuttycutty
December 23rd, 2010 08:32 PM
tecar442
July 25th, 2010 06:51 PM
blonzz
September 27th, 2004 10:54 AM
Quick Reply: Intake crossover
