455 Oil Filter Adapter Options
Old September 6th, 2017, 12:21 AM
th3ric3m4n's Avatar
A picture is worth a thousand words, yes? I ran into a problem tonight when installing headers. The oil filter adapter on this 455 is angled such that a filter (I'm trying to use Wix 51258) cannot be screwed on without hitting one of the primary tubes.
It looks like I need an adapter that points straight down or possibly perpendicular to the block. What other compatible filter adapter designs did Oldsmobile make?
th3ric3m4n is offline
Old September 6th, 2017, 05:35 AM
Since you're running headers you apparnelty aren't too concerned with keeping the car completely original. Would an oil filter relocation kit work?
https://www.summitracing.com/parts/trd-1122
The space between your oil filter housing and the header is negligible. I don't even know if you could get a shorter filter in there. Hopefully others have ideas too.
Olds64 is offline
Old September 6th, 2017, 06:39 AM
TripDeuces's Avatar
Is that from a Toronado? It seems to face forward too much. It should face straight down like the one in my pic. Although the one pictured is a oil cooler model the stock one would be shorter and still face down.
TripDeuces is offline
Old September 6th, 2017, 09:40 AM
72 Olds CS
RetroRanger's Avatar
pm sent
RetroRanger is offline
Old September 6th, 2017, 10:34 AM
Jpl67's Avatar
Rocket Racing in Wisconsin makes an oil filter adapter for better header clearance.
Jpl67 is offline
Old September 6th, 2017, 11:55 AM
You don't need an aftermarket adapter. You need to get rid of the Toronado oil filter adapter you have and install a correct RWD oil filter adapter.
joe_padavano is offline
Old September 6th, 2017, 12:24 PM
th3ric3m4n's Avatar
This block came from a pile of V8's in a junkyard, so I'm not sure what vehicle it was originally in. I seem to remember that I dated the block as an 1975. It did not have a Toronado pan with the indentation for the axle and also came with this angled oil filter adapter.
Old September 6th, 2017, 12:28 PM
Doesn't matter. That's STILL a Toro oil filter adapter.
Old September 6th, 2017, 03:23 PM
cutlassefi's Avatar
Correct. And the one from Rocket Racing will have the same position as the one you should be using, vertical. The only difference in the RR one is that it has slightly larger passages and doesn't have the relief valve.
cutlassefi is offline
Old September 6th, 2017, 08:44 PM
wr1970's Avatar
Do what Joe said and your problem is solved and the part is cheap.Ask around with a post in parts wanted forum and i bet someone has one.
wr1970 is offline
Old September 9th, 2017, 03:14 AM
Ozzie's Avatar
As noted, the vertical adapter will likely resolve your fitment problem. You may also want to consider something to reduce heat transfer from that nearby tube.
Ozzie is offline
Old September 27th, 2017, 01:11 PM
th3ric3m4n's Avatar
New vertical style filter adapter from RetroRanger installed and painted. The headers do not contact the oil filter anywhere. Excellent.
Old September 27th, 2017, 01:48 PM
72 Olds CS
Nice work, thanks Adam !!!
oldsonharmont
May 15th, 2022 04:45 AM
72 Olds Project
August 14th, 2011 12:41 PM
d2_willys
August 11th, 2010 03:07 AM
tim72
May 6th, 2010 10:58 AM
texasred
July 13th, 2007 08:53 PM
Quick Reply: 455 Oil Filter Adapter Options
