air cleaner paint
Old March 13th, 2014, 09:08 PM
painterbrad's Avatar
air cleaner paint
anyone know the color code or name for a 64 442 air cleaner and where to get it?
painterbrad is offline
Old April 18th, 2014, 04:50 PM
Keener's Avatar
-Duplicolor Chrysler Industrial Red Engine Enamal Paint: code 1632
-PPG poppy red. Not sure on the code anymore.
-I used the duplicolor product on my 64 442 air cleaner and it matched well with the original color on the base (the base was not faded, so it gave the best comparison). Can find at most local part stores.
Keener is offline
Old April 18th, 2014, 05:46 PM
Olds442redberet's Avatar
I had this one powder coated. IMO it looks close.
Olds442redberet is offline
Old April 18th, 2014, 05:50 PM
Here's the same color on a Rocket 350 in my 69 Cutlass S
Old April 18th, 2014, 06:41 PM
Keener's Avatar
The true color might be a little deeper red, but your AC looks really good. Basically the same color as the Duplicolor 1632 engine paint. To help painterbrad, what brand and code paint did you use?
Keener is offline
Old April 18th, 2014, 07:55 PM
That looks a tiny bit too red, and not quite orange enough, but between the variations of cameras and screens, it may actually be perfect for all I know.
Fusick has the exact right color. I know because the inside of my latest air cleaner was perfect, so after I painted the outside, I was able to hold the pieces next to each other, and there was no visible difference between the two.
MDchanic is offline
Old April 19th, 2014, 04:36 PM
The red I used is called Bengal Red. It's a primary color and is very close to Coca-Cola Red and the red used by Snap On for thier tool boxes. IMO I think you'd need a paint chip to actually see a difference. As far as what is correct for the Olds Air Cleaners, I have no idea. I'd recommend Fusik for exact colors.
Old July 1st, 2019, 10:33 AM
1968 442 Convertible
bry593's Avatar
Arise dead thread, resurrection!
I plan to paint my '68 442 air cleaner this weekend. Apparently, the consensus is that Ford Poppy Red is indeed a very close if not identical match to the original Olds color. I'll be using PPG Omni (Single stage activated urethane) over an MP170 catalyzed epoxy primer. The PPG code for Poppy Red is 60449 and current pricing is about $38 per pint (enough to spray 2-3 air cleaners). http://paintref.com/cgi-bin/paintdetail.cgi?ppg=60449
Anyone else try this color?
bry593 is offline
Old July 1st, 2019, 01:09 PM
ben442's Avatar
I recently painted my 68 air cleaner, here is how it looks and the custom mix I used.
ben442 is offline
Old July 1st, 2019, 02:00 PM
bry593's Avatar
Looks like a good match. Nicely detailed engine compartment! Looks better than new!
bry593 is offline
Old July 1st, 2019, 05:23 PM
Thumbs up 64 442 air cleaner color
Anyone that is still needing a paint code for a 64 442 air cleaner I was able to get a picture of it from my air cleaner. DuPont
took it and come up with code #738596. Hope this helps.
Old July 1st, 2019, 05:51 PM
Big Daddy Spo's Avatar
Air Cleaner Paint Color
I also used the -Duplicolor Chrysler Industrial Red Engine Enamel Paint: code 1632 on an air cleaner for my 64 Cutlass. I had an old can of the air cleaner paint from Super Cars Unlimited that I used on a 69 442. I was very surprised by how close they were. Here is a photo of the one on the 64:
Big Daddy Spo is offline
Old July 2nd, 2019, 09:00 AM
Keener's Avatar
Thanks for letting us know.
Keener is offline
Old July 15th, 2019, 03:26 PM
bry593's Avatar
Ok guys. Here is PPG 60449, Ford Poppy Red as shot on my 1968 code OG air cleaner. The picture was taken outside in an overcast condition, so should be fairly true to color. Does the shade look about right to you?
Here is Randy's '68 air cleaner in the original 48 year old (at the time of post) paint for comparison:
https://classicoldsmobile.com/forums.../#&gid=1&pid=2
bry593 is offline
abrasv
June 3rd, 2018 08:51 PM
f85 rocket
July 29th, 2016 12:51 PM
1969-442
August 11th, 2010 03:16 AM
Cameo White
Hurst/Olds
November 27th, 2008 06:34 PM
Want-A-Vert
April 2nd, 2007 08:15 AM
Quick Reply: air cleaner paint
