Click Here
Weird Wheels
Old Oct 7, 2013 | 07:04 PM
agreen316's Avatar
Weird Wheels
Hey all. My 'just purchased' 1970 Cutlass Conv has some strange wheels on it, and I can't find them on the web to see if they're worth anything. They have Buick center caps on a turbine-type wheel, but the turbine fins are flexible, like maybe they're rubber? I'd like to know what they are, to see if they're worthless or maybe worth tens of dollars. Any ideas?
Old Oct 7, 2013 | 07:15 PM
tecar442's Avatar
Pictures?
Old Oct 7, 2013 | 07:48 PM
NHolds's Avatar
Rubber wheels... this I gotta see.
Old Oct 7, 2013 | 07:54 PM
coppercutlass's Avatar
Chevy budget Olds powered
x2
Old Oct 7, 2013 | 07:59 PM
1970supremevert's Avatar
sound like a polycast wheel maybe, pics for sure, I think monte carlo came with a finned wheel that was polycast
Old Oct 7, 2013 | 08:14 PM
66400's Avatar
78-81ish Buick Regal wheels, steel 14" wheels with a styled rubber face.
Henry
Old Oct 7, 2013 | 08:30 PM
redoldsman's Avatar
Proud Viet Nam Veteran
You can't do anything without pictures. These should be interesting.
Old Oct 7, 2013 | 08:48 PM
hurst68olds's Avatar
Most of the manufacturers tried a POLYCAST wheel in the mid-'70s/'80s. Here's a 14" Chevy wheel.
Old Oct 7, 2013 | 10:40 PM
Diego's Avatar
I bet this is what he has:
Old Oct 7, 2013 | 11:09 PM
Those Oldsmobile Super Stock IVs only came in 5 on 5.00" bolt circle, so I doubt they are on the OP's '70 a-body.
These aftermarket Motor Wheel Corp. "EXITER" wheels were available with a 5 on 4.75" bolt circle.
Old Oct 8, 2013 | 12:45 AM
nsnarsk65cutlass's Avatar
Pics?
Old Oct 8, 2013 | 06:52 AM
Do they look like this, by chance?
As noted above, polycast wheels were a GM experiment in the 1970s to get the aluminum wheel look with steel wheel cost and durability. There's a steel wheel under structure with a molded polyurethane decorative outer face. The Pontiac honeycomb wheels were made the same way.
Old Oct 8, 2013 | 08:28 AM
Thou shall not mention Monte Carlo's of 1973 or newer manufacture in polite company. The GM redesign hit that car real, real hard; the 72 is beautiful, and the 73 is hideous.
Old Oct 8, 2013 | 09:22 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
What year & make of Buford are they off of Joe. Never seen a set. B body?
Old Oct 8, 2013 | 09:39 AM
rocketraider's Avatar
Oldsdruid
The 70 yes, the 71 maybe, but never the 72. Had too much unnecessary cheap-looking trim on it. The 73 rectified that with an elegant, swoopy, uncluttered design. Then they started that adding-unnecessary-trim cycle all over again until the 75-77 were really hideous. Think that baroque two-toning they put on them...
I think the OP's wheels are probably the Buick wheels Joe posted.
Old Oct 8, 2013 | 09:56 PM
agreen316's Avatar
Weird Wheels
Sorry for the no-pic question, and thanks for all the responses.
Our winner is Joe P., his pic is identical to what I've got on the Cutlass.
These things are hideous, is there any value to them??
Old Oct 9, 2013 | 01:14 PM
Nope. They are 5x4.75, used on late 70s/early 80s A/G body cars.
Old Oct 9, 2013 | 01:24 PM
Professur's Avatar
Beauty is in the eye. I kinda like them. No use to me tho, or I'd make an offer.
Old Oct 9, 2013 | 06:09 PM
Lady72nRob71's Avatar
If they are in good shape, put them up for sale on a Buick site. I am sure someone there would appreciate them.
WTony
Jan 15, 2011 07:53 PM
HurstOlds1775
May 7, 2009 05:09 AM
cisco88
Jul 6, 2008 04:03 PM
chadnum1
Apr 30, 2008 11:12 AM
1BAD68"S"
Brakes/Hydraulic Systems
Nov 17, 2006 04:20 PM
