Click Here
View Poll Results: Will these bolt up to my 10 bolt rear end or the 12 bolt i will be going with
18x10
100.00%
20x10
0%
Voters: 1. You may not vote on this poll
Need help asap please on these wheels
Old Oct 18, 2020 | 01:26 PM
Mlunsford33's Avatar
Im looking to buy these will and i want either a 18x10 or a 20x10 for the rear will they fit i have a 10 bolt rear end out of a 69 chevelle on my 70 olds now but will be going with a 12 bolt any info would be greatly appreciated
Old Oct 18, 2020 | 01:58 PM
You have not provided enough info for anyone to answer the question. What's the bolt pattern, backspacing, and offset? What tire size?
Old Oct 18, 2020 | 04:24 PM
Orlando 1's Avatar
O'smobile
If you have 10-inch wide wheels on the car now with the 10 bolt then you're ok. Just measure the overall width on the 12 bolt to confirm it is the same as the 10 bolt. Some rear axles change width. If it is the same, no problem. If I was testing an unknown axle, suspension, or spring I would bolt it up some smaller rollers for a baseline measurement. Take some turns on dips to really test the limit of travel. From there add wheel and tire size. In case you have future plans for the suspension remember that spring height and tension will be a clearance factor. Make sure ride height and spring firmness are final before choosing wheel size. Every fraction of an inch will get you closer to rubbing so establishing the baseline measurement is important.
They sound awesome, hope to see pics when you have them done!
droldsmorland
May 21, 2015 06:47 AM
bignasty442
Drivetrain/Differentials
Sep 10, 2011 07:23 PM
lexington
Wheels and Tires
Aug 10, 2011 09:03 AM
Southern_Hospitality
Jul 19, 2010 06:03 AM
ricardo
Mar 16, 2008 07:04 PM
