Click Here
15 inch trim rings
Old Jan 22, 2020 | 02:58 PM
Kolby66's Avatar
15 inch trim rings
Hello, I have purchased a set of Rallye II 15 inch wheels with the bolt on centers. My question is about the trim rings. Will the 15 inch trim rings from the later years work, or are there some differences in the stampings?
Also is there a big difference between factory and re-pop trim rings.Thanks
Old Jan 22, 2020 | 03:54 PM
Kolby66's Avatar
found answer
Old Jul 22, 2020 | 07:02 PM
code26's Avatar
Did you find aftermarket trim that fit right?
Old Jun 17, 2022 | 06:22 AM
1972 Hurst Olds's Avatar
Can you share what you found out as others like myself are searching for correct trim rings for SS2/3 with bolt on center caps
Cruzinbill
Aug 28, 2019 10:50 AM
JOHNNYOLDS442
Oct 20, 2015 07:34 AM
pfergy600
Nov 6, 2013 12:11 PM
RROLDSX
Wheels and Tires
May 22, 2013 10:49 AM
bummerino
Mar 14, 2010 07:53 PM
