Click Here
Tire dimensional information
Old January 31st, 2017, 08:13 AM
I found this table on the web. This is great info on the dimensions of older OEM tires. I'm making it a sticky.
joe_padavano is offline
Old January 31st, 2017, 10:38 PM
That's cool, Joe. I've got a few charts that compare "old" and "new" sizes, but none that run through the "inch number" sizes this way.
Thanks,
MDchanic is offline
Old February 1st, 2017, 05:26 AM
What is the minimum size factor column?
oldcutlass is offline
Old February 1st, 2017, 06:05 AM
Good question. It's apparently a made-up measurement that is the sum of the section width and O.D. I guess this is just a way to characterize wider vs. narrower tires of the same diameter. Here's a definition from the NHTSA:
E. SIZE FACTOR DETERMINATION
The actual size factor, which is the sum of the average tire section width and the outer diameter, is computed by the testing laboratory. The result is recorded on the test report in the space provided. The actual size is required to be equal to or greater than the preprinted minimum size factor.
Old February 1st, 2017, 06:08 AM
Thanks,
There are a lot of those "equivalency" charts on the web, but I find that I don't always agree with their selections. That's why I prefer to get actual dimensions and pick the tires myself.
Old February 1st, 2017, 06:58 AM
The ones I have show nominal dimensions, rather than equivalences, but actual dimensions are apparently subject to the whims of the gods.
This one is my favorite, though I do not recall where I got it originally:
File Type: pdf
MDchanic is offline
Old February 1st, 2017, 07:16 AM
Of course, tires are flexible and dimensions depend on rim width and inflation pressure.
Old February 1st, 2017, 05:37 PM
Gary
VC455's Avatar
Good find, Joe. The Tire and Rim Association is quite aggressive in keeping their pages off the internet.
VC455 is online now
Old February 1st, 2017, 05:42 PM
Better copy it to my HD, then...
MDchanic is offline
NDERISE
May 9th, 2016 08:32 AM
restoman
October 7th, 2009 01:34 PM
POKANOKET
July 14th, 2007 02:58 PM
lou_harris
January 4th, 2007 02:42 PM
<joyce>
June 11th, 2004 12:16 AM
Quick Reply: Tire dimensional information
