Click Here
Tire dimensional information
Old Jan 31, 2017 | 08:13 AM
I found this table on the web. This is great info on the dimensions of older OEM tires. I'm making it a sticky.
Old Jan 31, 2017 | 10:38 PM
That's cool, Joe. I've got a few charts that compare "old" and "new" sizes, but none that run through the "inch number" sizes this way.
Thanks,
Old Feb 1, 2017 | 05:26 AM
What is the minimum size factor column?
Old Feb 1, 2017 | 06:05 AM
Good question. It's apparently a made-up measurement that is the sum of the section width and O.D. I guess this is just a way to characterize wider vs. narrower tires of the same diameter. Here's a definition from the NHTSA:
E. SIZE FACTOR DETERMINATION
The actual size factor, which is the sum of the average tire section width and the outer diameter, is computed by the testing laboratory. The result is recorded on the test report in the space provided. The actual size is required to be equal to or greater than the preprinted minimum size factor.
Old Feb 1, 2017 | 06:08 AM
Thanks,
There are a lot of those "equivalency" charts on the web, but I find that I don't always agree with their selections. That's why I prefer to get actual dimensions and pick the tires myself.
Old Feb 1, 2017 | 06:58 AM
The ones I have show nominal dimensions, rather than equivalences, but actual dimensions are apparently subject to the whims of the gods.
This one is my favorite, though I do not recall where I got it originally:
File Type: pdf
Old Feb 1, 2017 | 07:16 AM
Of course, tires are flexible and dimensions depend on rim width and inflation pressure.
Old Feb 1, 2017 | 05:37 PM
VC455's Avatar
Barely Registered
Good find, Joe. The Tire and Rim Association is quite aggressive in keeping their pages off the internet.
Old Feb 1, 2017 | 05:42 PM
Better copy it to my HD, then...
NDERISE
May 9, 2016 08:32 AM
restoman
Oct 7, 2009 01:34 PM
POKANOKET
Jul 14, 2007 02:58 PM
lou_harris
Jan 4, 2007 02:42 PM
<joyce>
Jun 11, 2004 12:16 AM
