will this General tire fit '69 Cutlass?
Will General Altimax RT43 in P215/70R14 fit OK on stock '69 Cutlass steel wheels ... or too wide?
I want to keep original wheels and wheel covers.
Are you going blackwall? They do have OWL in the 225-70-14 in that model. I just received the picture from General tire a few weeks back. It's a brand new offering in white letter. I bought a set for my Impala. Very good tires.
215/70/14 is ~F70-14, the stock tire on a '69 442 (& others) with 14x6.0" wheels
225/70/14 is ~G70-14, the stock tire on a '68 H/O with 14x6.0" wheels
225/70/14 is ~G70-14, the stock tire on a '70 442 (& others) with 14x7.0" wheels
IMO go with the 225/70/14
My '69 is a Cutlass Holiday Sedan - 4 dr hardtop - not sure they have the same stock wheels as a 4-4-2? Maybe narrower?
I like the look of the Generals, and prefer a US brand to a Korean or other Asian brand.
Have a feeling the wheels are 5 inch width, but won't know for sure until I can demount a tire and measure.
So if 5" wheels is that wide enough for a 225 or should I stick to 215... I'd prefer wider... if it'll work.
Roger in NY
Roger in NY
1969 Oldsmobile A-bodies wheels are 14x5.0" or 14x6.0" (with the exception of the H/O's 15x7.0" wheels)
you will need to determine what size your wheels are - got pics? Do you know if they are original to the car? lots of changes in 50+ years
Something to consider no doubt. I have undersized tires on my ride, height wise. Its definitely noticeable. About 1 inch shorter than stock all around.
In any case, holidaysedan when it comes to tire size I am a stickler for manufacturer and distributor recommendations. Tire Rack.Com is a very handy site, their recommendations fall in line with manufacturers. P215/70R14 should not be put on a rim narrower than 5.5 according to them and i agree. P225/70R14 should not be on a rim narrower than 6 inches. Now this of course is going by the book, likely there is some leeway but I wouldn't chance it myself.
In my case I am doing the opposite of what you are leaning towards. I was aiming for the narrowest tire possible on a given rim while still having decent width. Of course this is a luxury I have because I went with aftermarket wheels. My front tires are max width 7 on a 7 inch rim and my rear tires are max width 8.5 on a 8 inch rim.
I'd bet they are 5" wide wheels since it's a lower line model with just the basic 2 bbl V8, but will verify before deciding.
I don't want to go too wide but am told generally 1 size up from stock is fine.
I may have to go with Hancook Optimo P205 or P215/75R14s. I used those 215s on a '68 Chev Impala w/ 14" wheels, as 215/75R14 was supposedly the replacement for the 8.25/80-14 stock tire, but it seemed too small, and GM and other mfr's tended to save $ by putting under-sized tires on cars at that time, they were often criticized by the car mags for that... bad GM! They seemed a tad small on that car, however may be ok on my Cutty, but I kind of wanted a better quality US-made tire... options are very limited.
Whats more important too you, road feel, looks, or efficiency ? How do you feel about BF Goodrich Radial T/As.
I have had them on my 69 as well as other Olds over the years and they are the widest looking tire bar none. They look great on recommended rim widths, and seem to have the closest thread width appearance to sidewall bulge out-there.
The one thing they aren't is lightweight. I'm sure that extra weight is the reason they look so full.
For me lightweight supersedes everything. My car has a great deal more unsprung weight than it came with from the factory, so I am perpetually trying to reduce that. My fronts are currently Firestone's, and the rears are Cooper Cobras. The mismatch is intentional. They are both the lightest for their size that i could find while being comfortable with the brand etc.
PS I looked into my notes regarding factory rim specs. I see 1969 GM 14 x 5 steel rim code YL nos weighing 17 lbs, written down. Also I have notated that my Supreme came with 14 x 5.5 steel rim weighing 18 lbs + hubcaps, and that the factory bias plys were approximately 22 lbs each. Hopefully someone can either verify this info or set me straight ?
100% correct !
When in doubt like Joe P always says, go to the Chassis Service Manual. Which is exactly what I did.
These pics are from the 1969 Oldsmobile Chassis Service manual.
holidaysedan obviously you and I share the same base standard wheel. In turn this severely limits your tire options if going by the book.
PS according to the Automobile Catalog that matches this information, our base standard tire was 26.4 inches in diameter. I had believed the base standard tires were 27.10 in diameter. So I am not as off in height as I thought I was. When I first got the 69 it had 225 70 15 BF Goodrich Radial TAs on 15 x 7 SS IIs. Very tall, 27.4 in diameter and filled the wheel well beautifully height wise..
Phil: you and Joe are spot on, it never occurred to me to look in the CSM, so I just did, and there it is right on 10-5.
So now I know that 14" x 5" is the wheel, I'm hoping P215/70R14 will work, 205s just seem so small, then again as mentioned before, GM and the other companies were known for using undersized tires in those days.
bigjaythe1st
Wheels and Tires
February 22nd, 2012 01:37 PM
