Click Here
Wide tires
Old May 7, 2024 | 02:00 PM
PatinaManDan's Avatar
Wide tires
Hi new here, I’m looking at buying a 1969 Oldsmobile Cutlass Supreme and I want to put wide tire on all 4 corner, my question is how wide can I go… I see a lot of 285 on the rear and around 255 front. Has anybody squared up there cutlass and if so what was the tire width?
Old May 7, 2024 | 02:28 PM
Welcome! Check out this thread on this site, you should find what you're looking for. Good luck!
https://classicoldsmobile.com/forums...-yours-105914/
Old May 7, 2024 | 07:47 PM
Mr Nick's Avatar
Depending on how low the ride height is, and how much caution you want to use while driving... will determine how wide you can go up front.
I ran 255/45/18 up front for years with no issues with about 2-3" lowered suspension. It would rub the sway bar just a touch reversing out of my driveway at full lock.
You could run 275 square, but the front may cause issues if you're lowered. If it's not lowered, I think (personal opinion) a 275/40 up front will look goofy due to the wheel gap and low profile tire. If you don't mind being extra cautious when driving, then you could go for it.
275 in the back is easy, 285 is getting a little snug and will require proper offset. 295 is doable but everything has to be right. Even worn out rubber bushings will allow the rear end to move around and may rub the quarter panel lip or tail pipes.
I'm currently running 245/45/18 on 8" wheel up front, and 285/40/18 on a 10" wheel in the back. Car is lowered about 2-3" overall.
Old May 7, 2024 | 08:31 PM
good information thanks for that
Old May 8, 2024 | 01:30 AM
I ran 255/60-15s on the stock 15x7 wheels at all four corners of my 69 H/O. There was a very minor rubbing in the front if I hit a bump with the wheels turned to the stops. Other than that, no issues. You can run wider at the rear, but not really at the front.
Old May 8, 2024 | 04:07 AM
thanks for the reply
Old May 8, 2024 | 06:05 AM
fleming442's Avatar
You can put almost whatever you want on the car. The question is: how bad do you want it?
Old May 13, 2024 | 02:14 PM
72_supreme's Avatar
Just put it on the ground and hour ago after tons of brake work. 275/40r18 square, Conti extremecontact02. No rubbing anywhere, at least while stationary. Wheels are 18x9.5 5.5 backspace.
Old May 13, 2024 | 02:16 PM
Originally Posted by 72_supreme
Just put it on the ground and hour ago after tons of brake work. 275/40r18 square. No rubbing anywhere, at least while stationary. Wheels are 18x9.5 5.5 backspace.
looking good
Old May 13, 2024 | 02:28 PM
72_supreme's Avatar
Thanks, forgot to state it has BMR 2" lowering springs at all 4
Old May 13, 2024 | 02:30 PM
well I think it’s got the perfect stance
Old May 13, 2024 | 03:13 PM
72_supreme's Avatar
Appreciate it. Tomorrow I'll see if I can get it to move AND stop for the first time in 14 years or so.
Old May 13, 2024 | 03:14 PM
good luck I’m sure it’ll be fine
Old May 13, 2024 | 11:15 PM
Well, with the wheels straight ahead, I wouldn't expect it to rub. Turn the wheels to the stops in each direction and bounce the suspension. That's when the fronts will rub.
Old May 14, 2024 | 07:56 AM
72_supreme's Avatar
By stationary I was talking about not being driven and dealing with suspension travel. Lock to lock the fronts clear. Backs are obviously fine. Was running 275/60r15 drag radials before
Old May 14, 2024 | 07:02 PM
Mr Nick's Avatar
Looks good!
is that a Viper in the background?
Old May 14, 2024 | 07:17 PM
72_supreme's Avatar
Looks good!
1997 GTS. After a lot of false starts and issues on getting the olds on the road again I bought it last year. Now I have to get the Cutlass going because 1 passenger seat and 2 kids is just always arguments over who has been driven to more practices in the cool car for the week. I was close to dumping the Cutlass to free up more cash on it but the wife actually likes the Cutlass despite never being roadworthy in the time we've known each other.
Old May 14, 2024 | 08:16 PM
Mr Nick's Avatar
Good problems to have.
My wife doesn't mind the occasional cruise in the Cutlass, but she doesn't like the windows down because it messes up her hair. With no AC, that means I'm usually cruising solo in the summer.
My son is only 2 years old. will be a few more years before I'm comfortable putting him in the Cutlass.
Sep 5, 2021 09:42 AM
StarRacer
Apr 9, 2021 06:42 PM
Magna86
Wheels and Tires
Mar 27, 2014 06:44 AM
jasag24
Mar 11, 2010 07:09 AM
Satellitecentral
Nov 6, 2008 10:52 AM
