Wheel Change Question
Looking at a used set of 15x7 wheels. I currently have 225 70 R14's on 72 Cutlass Convertible. Anything to consider about changing wheel sizes? How much change will I have in the stance of the car and clearances? Anything to worry about or things to think over?
A site for future reference on wheels.
http://www.wheelsanything.com/
About the only thing I can think of is changing the overall diameter of the wheel/tire will change your speedo reading. You can either use GPS to calculate your actual speed, or you can change the speedo drive gear in the tranny. Other than that? Let's see what you're looking at! BTW I run 225/70/14's on my Cutlass and the speedo is off with them too. Original size for my car was F/78/14 which would be closer to a 195/60/R14 I think. I like the handling and ride of the 225's though.
I just put 245/60R15s on my '71. Fills the wheelwell nicely. My speedo reads about 5mph faster than actual. Ride is great. I get a little rub agaist the stabilizer bar from my right front at full lock. No issues otherwise.
STLCRZY
Suspension & Handling
July 25th, 2011 10:53 AM
71cutlasshardtop
September 19th, 2007 08:01 PM
