Wheel Alignment
Wheel Alignment
Hi Olds People,
I'm looking for some wheel alignment data for my 1952 Super 88.
I want to change the steering tie rods and after that I'd like to align everything in the right position.
so, does anybody have some data and/or advice how I can align everything?
Best regards,
Kai
Best regards,
Kai
Hi Olds People,
Best regards,
Kai
Best regards,
Kai
Caster: N3/8 degree
Camber: P1/4 degree
Steering axis inclination: 4-1/2 degrees
Toe-in: 3/32 inch
Toe-out on turns (inner wheel): 20 degrees
Toe-out on turns (outer wheel): 23 degrees
What is a Glenn's Manual?
Think I should get one too.
Thank you very much for your answer
Ok probably for bias plies and really easy steering, my post was for a radials setting.
It was an auto repair manual for American cars by Harold T. Glenn; published by Chilton Company; copyright 1960 & 1961. It is likely "out of print" for a long time. You may be able to get an old used one from Amazon or a similar place. I bought mine new in the 1960s in a bookstore.
