Click Here
weird.....
Old Dec 13, 2018 | 10:26 AM
Eddie Hansen's Avatar
weird.....
Ok so I have an issue with my rear disc brake calipers, made to fit a 15" wheel, we all know they interfere with the ss2 factory wheels and there are three solutions that I see,
1. grind the new powder coated calipers (not what I wanted to do) that's out
2. Use a wheel spacer as others have done ( I don't like the idea of the spacer as I am going to drive the car, but may consider it if anyone has a safe and fool proof part that will work)
3. change the wheels ( this is the reason for my post) I purchased hurst dazzler wheels, I searched the forums and weighed the info and decided on a 15 x 7 wheel all the way around. so I pop over to summit and found these in the correct bolt spacing etc
https://www.summitracing.com/parts/vsw-s0041/applications/make/oldsmobile
then the shopping cart says check application so I press that button and it says this is wrong for your vehicle? WTF? but it is ok for a 1975?
what gives? I ordered them anyway but why would it give me that message? Will I have issues with this wheel?
Old Dec 13, 2018 | 12:06 PM
Dave26's Avatar
The reason it says wrong for your vehicle, is because your car came from the factory with 14" wheels. The program algorithm is set up for original equipment. We all know that 15" wheels will fit. Assuming that lug holes, backspace, tire size are correct.
Old Dec 13, 2018 | 02:34 PM
Agreed. The SS wheels changed to 15" in 1975.
Old Dec 13, 2018 | 05:43 PM
Thanks fellas they are on their way, LOL. one other question if anyone knows about these type of wheels can I have the gold painted and clearcoated in the same colour as the stripes when I finally get to paint? I am assuming it was bc/cc? not anodized etc I am building a 69 hurst olds convertible clone would like the golds to match
speedaddict78
Wheels and Tires
Jan 16, 2013 09:27 AM
jerseyjoe
Feb 8, 2011 04:59 PM
basssnake
Jan 16, 2011 12:26 PM
t bell
Aug 18, 2009 08:21 AM
shaunr
Jan 19, 2007 09:56 PM
