Tire/wheel size question
I posted this in another category before I realize there was a wheel/tire specific thread so here it is again. Thanks. I have a 1972 ]Cutlass S that I am going to finally start dressing up. I've been reading as much as I can on the net(mostly from 442.com). What I would like to do is put 15x7- 3.75 backspaced American Racing Torque Thrust wheels on the front with BF Radial T/A 225 60's. 15x8.5-3.75 backspace with the 275 60 T/A's on the rear. I can afford this set up but not much more. From all accounts this will work from what I have researched. Could I get some advice from you guys about my thoughts before I order as to clearance problems and such. It would be much appreciated. Thanks, Joe
I'm running 255/60/15 in the front and 275/60/15 in the rear with no problems. Still have room on my 72. Stock height springs though. I had the front 1" lower a couple of years back and it rubbed a little in a tight turn.
Post some of the pic . I am in the same boat. I just bought 15x8 ssI's. I am leaning towards Ziff's combo but have thought of 295/50's in the back with 255/60's up front. Would like to see some more combos
wide fronts
That will feel like a skid steer. Way too wide in the front in my opinion.
I am running the same as you, never any problems and rides and handles well....
Here's 245/60/15 F and 275/60/15 rear on 15x7 and 15x8. For 15" I think this is the perfect combo for 70-72 for street. Will be getting some 325/50/15s and 15x10s for the track soon but 2.5" tail pipes need to be moved "in" about an inch to make room:
BTW - I had one car that 255/60/15s hit at full turn and another car that didn't hit at all. Safest to go with 245/60/15 max on the front to be safe IMHO.
i got 205/60 15" in the front and 245/60 15 rear tomorrow im going to see if i can get 275/60/15 for the rear as my tires dont hold grip to good
