Click Here
Tire/wheel size question
Old Nov 7, 2013 | 09:07 PM
rockdog2112's Avatar
I posted this in another category before I realize there was a wheel/tire specific thread so here it is again. Thanks. I have a 1972 ]Cutlass S that I am going to finally start dressing up. I've been reading as much as I can on the net(mostly from 442.com). What I would like to do is put 15x7- 3.75 backspaced American Racing Torque Thrust wheels on the front with BF Radial T/A 225 60's. 15x8.5-3.75 backspace with the 275 60 T/A's on the rear. I can afford this set up but not much more. From all accounts this will work from what I have researched. Could I get some advice from you guys about my thoughts before I order as to clearance problems and such. It would be much appreciated. Thanks, Joe
Old Nov 12, 2013 | 04:31 PM
Why 225-60s up front? Those are really short and not very wide. 235 or 245 would fit with no issues and probably be easier to locate. I ran both of those sizes in the past.
Old Nov 12, 2013 | 04:56 PM
ziff396's Avatar
I'm running 255/60/15 in the front and 275/60/15 in the rear with no problems. Still have room on my 72. Stock height springs though. I had the front 1" lower a couple of years back and it rubbed a little in a tight turn.
Old Nov 13, 2013 | 01:36 PM
Thanks for the info guys. I'm looking at as many pics as I can for the look I want. Thanks again.
Old Nov 13, 2013 | 04:51 PM
Sampson's Avatar
Post some of the pic . I am in the same boat. I just bought 15x8 ssI's. I am leaning towards Ziff's combo but have thought of 295/50's in the back with 255/60's up front. Would like to see some more combos
Old Nov 13, 2013 | 05:28 PM
oldsmobiledave's Avatar
wide fronts
255 60 15s up front?...Really?
That will feel like a skid steer. Way too wide in the front in my opinion.
Old Nov 13, 2013 | 06:22 PM
Sampson's Avatar
You may be right! Still researching. 235's?
Old Nov 15, 2013 | 04:23 PM
As I posted above, I have run 235-60 and 245-60 up front with good results. Either one should work well for you.
Old Nov 15, 2013 | 04:36 PM
ziff396's Avatar
I like the look and it handles very well. Been running them almost 4 years now. I had the same setup on a chebby. I like it.
Old Nov 15, 2013 | 04:46 PM
sammy's Avatar
Sammy70 455 Supreme
I am running the same as you, never any problems and rides and handles well....
Old Nov 16, 2013 | 01:24 PM
svnt442's Avatar
I ran 255/60/15's all the way around on a 70 Cutlass S I had years ago when I worked for Super Shops. They were take-offs from a 72 Corvette. Free tires always works for me.
Old Nov 16, 2013 | 03:19 PM
I had 255/60-15s on all four corners of my 69 H/O on the factory wheels with no problems. Car drove and handled great.
Old Nov 17, 2013 | 01:58 PM
71 OLDS's Avatar
Here's 245/60/15 F and 275/60/15 rear on 15x7 and 15x8. For 15" I think this is the perfect combo for 70-72 for street. Will be getting some 325/50/15s and 15x10s for the track soon but 2.5" tail pipes need to be moved "in" about an inch to make room:
BTW - I had one car that 255/60/15s hit at full turn and another car that didn't hit at all. Safest to go with 245/60/15 max on the front to be safe IMHO.
Old Nov 18, 2013 | 05:17 PM
PL ENDO's Avatar
i got 205/60 15" in the front and 245/60 15 rear tomorrow im going to see if i can get 275/60/15 for the rear as my tires dont hold grip to good
Old Nov 18, 2013 | 05:23 PM
PL ENDO's Avatar
not sure where you live but im planning on changing my wheels and tires so i might be able to sell you the wheels and tires save you some coin
Old Nov 25, 2013 | 07:28 AM
Thanks for the offer. I went with the US Mags Standards in silver. 225/60 on 15x8 on the fronts and 275/60 on 15x9 on the back. I think it looks pretty sharp. Before and after.
Old Nov 25, 2013 | 03:10 PM
Looks good.
Hang on to those original wheels. Steelies and hub caps are probably rare these days and may be valuable to someone doing a resto.
Old Nov 25, 2013 | 04:22 PM
PL ENDO's Avatar
im sure the bath helped a little as well. it does look good
Old Nov 25, 2013 | 04:57 PM
Much better, x2 on the steelies.
Old Dec 1, 2013 | 07:24 PM
Looks good.
They are safely tucked away in the shop. One will have to be used for a spare for a little while.
davidstereo
Wheels and Tires
Sep 23, 2012 05:45 PM
CurtRod58
Wheels and Tires
Aug 28, 2010 01:49 PM
nmtt92
Mar 16, 2009 10:15 AM
littlejm3
Mar 2, 2008 06:35 AM
ss427
Jan 15, 2008 07:47 AM
