Click Here
Tire Question
Old Jan 21, 2018 | 07:47 PM
Frisbee_k9's Avatar
Tire Question
I have a novice tire question.
If I have two different size tires what size would I use as a spare?
P215/65R15 front
P255/60R15 rear
Thanks, Guy
Old Jan 21, 2018 | 09:04 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The 215/65R15 will take up less space in the trunk, an inch difference between the two. I have 205/75R14 and 215/75R14 on my 70S so I just carry an extra 215/75R14 in the trunk. With my 88 CSC, I have 205/70R14 on the front and I am putting 225/70R14 tires on the back, so I will carry a 205/70R14 and a 215/75R14 since I have a couple extra.
Old Jan 22, 2018 | 01:17 AM
Frisbee_k9's Avatar
Thanks for the prompt follow up.
Old Jan 22, 2018 | 03:55 AM
The question should be, can I run 2 different size tires on a posi rear end over a long distance without doing damage. If you have a posi, the spare should be the same size as the rear tires.
Old Jan 22, 2018 | 07:50 AM
Actually, the posi (OK, Anti-Spin... ) only cares about tire diameter, not width. The 255 might be a clearance problem at the front. Consider getting a spare that is the same diameter as the 255/60, but narrower. You want a tire with a 27" OD. If you can find a 235/65-15, that would be perfect. 205/75-15 would be close (27.11" diameter vs. 27.05").
Old Jan 22, 2018 | 08:38 AM
That's what I meant as there was 1.04 difference in diameter between the fronts and back.
Old Jan 22, 2018 | 08:52 AM
Read my response again. Use a spare that matches the diameter of the REAR tires (to avoid posi problems) but with the width of the FRONT tires (to avoid rubbing problems. Yeah, the different diameters in the front may cause it to pull slightly, but it won't damage anything and you're only driving to the next exit off the freeway.
jasag24
Mar 11, 2010 07:09 AM
69442
Apr 9, 2009 06:48 AM
audiodox
Feb 13, 2009 01:22 PM
ragtop442
Jul 4, 2008 12:13 AM
shaks 442 clone
Jul 21, 2007 08:48 PM
