Click Here
Tire Comparison Calculator - not sure whether to trust or not…
Old June 18th, 2023 | 08:32 PM
cfair's Avatar
Just digging around online and came across this site that does tire size comparisons:
https://tire-calc.com/comparison/225...5-60-r15-inch/
You all know more than me, I’m just wondering if I can trust their calls. Do they look reasonable to you all?
Chris
Old June 18th, 2023 | 10:56 PM
Yes it's probably correct, I use the one on Discount tire. There may be a small difference between tire manufacturers.
Old June 19th, 2023 | 02:19 PM
I wrote my own in Excel. I find that these calculators are frequently all over the map. Also keep in mind that sidewall flex changes the effective rolling radius. Radial tire sidewalls flex more than those on bias ply tires, so even if the theoretical diameter is the same, the radial will have a smaller effective rolling radius. Also note that tires with shorter sidewalls have less sidewall flex, so even though (as an example), 275/60-15 and 275/50-17 have nearly the same theoretical diameter, but the shorter sidewalls on the 17" tire (5.4" vs 6.5") will result in a slightly larger effective rolling radius than for the 15".
Old June 19th, 2023 | 03:19 PM
I was surprised when I put a yard stick against my tire and saw it was quite a bit shorter than what the manufacturer's spec showed.
Bfg
June 1st, 2018 05:50 AM
midrange
November 8th, 2016 02:28 PM
Tedd Thompson
Wheels and Tires
November 7th, 2013 09:25 PM
Evans1
February 9th, 2013 01:07 PM
Mister
Wheels and Tires
58
October 27th, 2010 05:57 AM
