Click Here
Tire Comparison Calculator - not sure whether to trust or not…
Old Jun 18, 2023 | 07:32 PM
cfair's Avatar
Just digging around online and came across this site that does tire size comparisons:
https://tire-calc.com/comparison/225...5-60-r15-inch/
You all know more than me, I’m just wondering if I can trust their calls. Do they look reasonable to you all?
Chris
Old Jun 18, 2023 | 09:56 PM
Yes it's probably correct, I use the one on Discount tire. There may be a small difference between tire manufacturers.
Old Jun 19, 2023 | 01:19 PM
I wrote my own in Excel. I find that these calculators are frequently all over the map. Also keep in mind that sidewall flex changes the effective rolling radius. Radial tire sidewalls flex more than those on bias ply tires, so even if the theoretical diameter is the same, the radial will have a smaller effective rolling radius. Also note that tires with shorter sidewalls have less sidewall flex, so even though (as an example), 275/60-15 and 275/50-17 have nearly the same theoretical diameter, but the shorter sidewalls on the 17" tire (5.4" vs 6.5") will result in a slightly larger effective rolling radius than for the 15".
Old Jun 19, 2023 | 02:19 PM
I was surprised when I put a yard stick against my tire and saw it was quite a bit shorter than what the manufacturer's spec showed.
Bfg
Jun 1, 2018 04:50 AM
midrange
Nov 8, 2016 01:28 PM
Tedd Thompson
Wheels and Tires
Nov 7, 2013 08:25 PM
Evans1
Feb 9, 2013 12:07 PM
Mister
Wheels and Tires
58
Oct 27, 2010 04:57 AM
