Click Here
Super Stocks and rubber
Old Jan 3, 2013 | 05:48 PM
SteveB's Avatar
Question Super Stocks and rubber
Hi all,
'71 cutlass coupe. Has original 14 x 7 (as I understand) steel wheels. Just purchased a set of restored SSIIs, 14 x 6, so I'll be looking for new rubber too.
Main question is, anybody know what would have been the factory performance tire style? Whitewall or white letter?
Old Jan 3, 2013 | 05:59 PM
1970cs's Avatar
Lansing built
Your options were one of these on H/O and 442 of that era.
Pat
Old Jan 3, 2013 | 06:02 PM
SteveB's Avatar
tires
cool, thanks. Actually was expecting whitewalls, but I can defintely do letter.
Old Jan 3, 2013 | 09:22 PM
rcorrigan5's Avatar
Randy C.
If you are looking to keep your car as "origiinal" as possible, the SSII wheel for '71 was 14X7.
Randy C.
Old Jan 3, 2013 | 10:46 PM
hurst68olds's Avatar
1971 Cutlass & Cutlass S coupes
F78-14 blackwall STANDARD - dual whitewall OPTIONAL
G78-14 blackwall STANDARD with V8 or A/C - dual whitewall OPTIONAL
G70-14 white stripe OPTIONAL
G70-14 raised white letter OPTIONAL
Old Jan 4, 2013 | 05:51 AM
SteveB's Avatar
Wink "original?"
If I wanted it to be as "original" as possible, I wouldn't be putting Super Stocks on a "base" Cutlass...
Plus the 6s were the ones that I found and liked and were affordable. So there it is.
I think I can live with the 6 v 7 discrepancy.
Forgive my ignorance... is that number just the wheel root width, in inches?
Old Jan 4, 2013 | 05:56 AM
SteveB's Avatar
Question thanks...
Not really sure where mine falls.
I'd assume G70.
2dr coupe 350R 2bbl, no AC, no frills.
Old Jan 4, 2013 | 05:58 AM
dc2x4drvr's Avatar
The 14x7 SSI wheel accepts a deeper trim ring, and fits disc brake cars.
Old Jan 4, 2013 | 06:00 AM
SteveB's Avatar
Ah, I see. Well I got 4-wheel drum so that's not an issue.
Old Jan 4, 2013 | 08:16 AM
Uh:
And yet again, ALL SSII/III wheels of ANY factory width will clear factory disk brakes.
Old Jan 4, 2013 | 08:25 AM
SteveB's Avatar
That's quite a resume'
Old Jan 4, 2013 | 09:30 AM
1970cs's Avatar
Lansing built
I'd assume G70.
F78-14 blackwall standard, unless you have a build sheet or window sticker to show ordered optional tire! FYI if it's Lansing built the build sheet will not be there!
But the OP you asked for performance tire!
Pat
Old Jan 4, 2013 | 10:21 AM
SteveB's Avatar
Yes, the question was really,
"What's the typical tire style (from factory) with SS wheels?"
Don't really want to put standard blackwalls on SS wheels.
Old Jan 4, 2013 | 11:49 AM
1970cs's Avatar
Lansing built
Understood! still blackwalls, factors that change on a 33687 body style choice on tires as far factory standard C60(A/C) FE2(suspension pkg).
This still brings us back to build sheet or window sticker.
This info is free by joining wildaboutcars.com and you can spend hours just on your car plus online service, chassis, and parts # manuals.
I'll go little further that if you want decent handling, modern radials would be best! But the issue is 14" tires are getting thin! Your choices on brand name RWL in P225-70-14 are as follows B.F.Goodrich, Cooper Cobras and Firestone Firehawks.
Pat
Old Jan 4, 2013 | 01:03 PM
I agree all this info is on & from "Wild About Cars"
1971 V8 Cutlass - $3021.00
A/C - $407.59 - requires power steering
Power Steering - $115.85
SSI - $90.58
G70-14 white stripe - $64.25
G70-14 rwl - $103.21
Today these prices look like small potatoes - but the SSIs & RWLs (OPTIONAL wheels & tires) added ~7% to the base V8 Cutlass.
$2K on one of todays ~$30,000 new cars.
The Bug Man
Feb 11, 2014 05:52 PM
1965olds
Feb 5, 2014 12:01 PM
1965olds
Dec 2, 2013 09:39 AM
joe_padavano
Sep 26, 2013 05:44 AM
Oldssupreme
Jan 24, 2013 07:36 PM
