Click Here
SSIII wheel? Will disc brakes fit?
Old Oct 30, 2019 | 06:35 AM
Phoenix8990's Avatar
I have a 69 Cutlass conv that came with these 14" wheels. From reading other threads I think they are SSIII from the 80's. What I would like to know is if they are in fact that and if I upgrade to disc brakes will the caliper clear? I would think all cars from the 80's would have come with disc brakes.
thanks,
Steve
Old Oct 30, 2019 | 10:20 AM
exotec's Avatar
Olds Omega
Right Stuff Detailing, Wilwood for example are offering disc conversion for that 14” wheels.
I odered the right stuff version as it looks more original with the 1 piston caliber
Old Oct 30, 2019 | 01:15 PM
don71's Avatar
same but different
That wheel should fit stock disc brakes. The pic below shows the difference in stock wheels. #1 fits disc brakes. #2 does not. Photo courtesy of another CO member.
Old Oct 30, 2019 | 01:18 PM
Ok, great, I'll check out my rims. Am I correct on them being SSIII from the 80's?
thanks,
Steve
Old Oct 30, 2019 | 01:44 PM
don71's Avatar
same but different
thanks,
Steve
Yes, that would be my best guess from your pic.There are some numbers stamped on them if you can locate,including a date code. I'm not versed in decoding them, but somebody here sure is.
Old Oct 30, 2019 | 03:36 PM
14" wheels with snap on center caps would be from that era. The early (60s-1974) 14" wheels had bolt on center caps.
Old Oct 30, 2019 | 05:20 PM
Every single SSII/SIII wheel ever made by Oldsmobile clears factory 10.75" disc brakes used on A-body and G-body cars. Nearly all of the 1967-1972 cars made with disc brakes came with 14" wheels from the factory. Only the 69 H/Os came with 15" wheels in that period.
Old Oct 30, 2019 | 10:36 PM
exotec's Avatar
Olds Omega
That’s great info! Makes me feel sure that disc conversation will work with my 14” SSIII
johnnyrockets
Wheels and Tires
Jun 4, 2016 07:03 AM
Roger60
Wheels and Tires
Oct 12, 2015 09:32 AM
Wedgewood Rod Shop
Brakes/Hydraulic Systems
Jan 10, 2015 08:38 AM
jimigisme
Feb 8, 2014 05:49 AM
Ablast
May 21, 2012 07:34 PM
