Click Here
Rim center cap installation
Old Jan 10, 2026 | 05:06 AM
1998rims's Avatar
I have 1998 Aurora chrome rims.
Each time I try and install the center cap, I break clips.Half the time I get work done on my car, the caps end up falling off because the technician didn't put them on properly.
How do I properly remove/install the center caps without breaking any clips?
Old Jan 10, 2026 | 06:12 AM
It should just snap into place for installation, to remove pry on either of the 2 notched areas that are 180* from each other.
Old Jan 10, 2026 | 06:30 AM
1998rims's Avatar
Thanks for the reply.
Any attempt to snap it on, without doing anything else, always results in tabs breaking off.
I took it to a Cadillac dealer once, and their service guy also broke tabs off when they tried.
Old Jan 10, 2026 | 09:05 AM
Could it be they are just getting old and brittle?
Old Jan 10, 2026 | 10:47 AM
1998rims's Avatar
I would say none of the caps are original to the wheels.
I've been getting them off of ebay since I keep losing/breaking them. I can't vouch for their age/quality vs the originals.
Any attempt to force them on breaks at least 1 tab. They usually stay on with 1-2 broken tabs but they don't sit flat and eventually fall off.
https://www.ebay.com/itm/360394370650
Old Jan 10, 2026 | 02:14 PM
Are you using the correct lugnuts?
Old Jan 10, 2026 | 02:31 PM
1998rims's Avatar
They're the ones that were on it when I got it so I am not sure.
The tabs start breaking before the cap gets to the lugnuts though.
Old Jan 11, 2026 | 09:42 AM
1970cs's Avatar
Lansing built
Maybe a heat? Set in the sun tabs up for a few hours, soak in warm water.
Pat
dream66
Wheels and Tires
19
May 18, 2024 02:50 PM
442Harv
Dec 5, 2023 01:06 PM
first442
Jul 17, 2019 10:52 PM
bobb
Wheels and Tires
17
Feb 6, 2016 01:36 PM
brddg
Jul 4, 2013 06:01 PM
