Click Here
Right tires for 14 x 7 SSI's
Old Feb 29, 2012 | 07:21 AM
Blackpage's Avatar
They will be going on a Twilight Blue 1970 Cutlass S with disc brakes in front. Looking for the right size raised white letter tires that will best fill the wheel well in height, width and girth without looking too overinflated or bubbled. Any suggestions ? Maybe pictures of your set up? Point me in the right direction?
THANK YOU
Old Feb 29, 2012 | 07:32 AM
hookem horns's Avatar
I think 225/70/14 is your best option on the dwindling supply of 14" tires. BFG or Firestone. Pricier options exist if you want original style belted tires.
Old Feb 29, 2012 | 08:07 AM
1970cs's Avatar
Lansing built
1 more
Cooper cobras are available in that size.
I agree that the 14" choices are getting very thin!
Pat
Old Feb 29, 2012 | 08:17 AM
Rocketbrian's Avatar
That will be a beautiful looking car. Twilight blue is awesome. A friend of mine had a 70 SX W32 in Twilight blue. It has SS1s with Goodyear Eagle STs (no longer available), the same tires as on my 71 SX. I will need new tires this year and will have to get the 225/70-14 BF Goodrich. The 225/70-14 tire size is the correct replacement for the original G70 -14 size. I'm trying to send pictures, but the Forum isn't allowing them for some reason. I'll try later.
Old Feb 29, 2012 | 09:37 AM
scott_442's Avatar
These are 225/70/14 Firestones...paid about $80/each.
Old Feb 29, 2012 | 09:44 AM
Blackpage's Avatar
Thank you Gentlemen. 225-70-14 it is. Scott 442's picture sealed it. The exact look I'm after. Thanks again.
Old Jun 24, 2012 | 04:24 AM
my442conv's Avatar
Ditto on the tiles for the SS1's..............also on the Twilight Blue color, awesome color for the 442
Joe
Old Aug 7, 2012 | 08:41 PM
Alex72cutty's Avatar
@ Scott_442. Did you buy the firestones online. I'm in the market for some 14inch tires.
Old Aug 7, 2012 | 09:30 PM
trucker442's Avatar
trucker442
ss1
I have the bfg radial ta's that are 225 704's, I think they look pretty good...
Old Aug 7, 2012 | 09:33 PM
oldsmobiledave's Avatar
my 2 cents
The right tires for these rims are any that hold air. Then these rims can be used to store your car on. Set them aside & put some 15" rims on the car. It will improve the look & the handling & your choice of sizes is far superior.
Old Aug 15, 2012 | 05:31 PM
tcarroll's Avatar
I'm looking at tires for my 1968 Cutlass S and want to go with B.F. Goodrich Redlines
I have 1970 ssi rims so the outer part of the rim is painted black and only the inner rim is chrome. They originally took trim rings in 1970 but i want to leave them just painted black with no trim ring. I looked a t a buddys 1970 Cutlass S with 225/70R14 tires on it and i thought it looked kind of large in the wheel well. I was going to pu ton 215/70R14 on it but now reading this post everyone is saying 225 is the right size. i thought an F70 was a 205 and a G70 was a 215 but someone on hear said a G is a 225 can anyone verify? Thanks
Old Aug 15, 2012 | 08:37 PM
trucker442's Avatar
trucker442
tcarroll
tcarroll, according to tire size helper the g70 14 was 26.8" od with 782 rpm's closest fit is a 225 70r14 wich is 26.4 od and 764 rpm's. The f7014 are 26.2 od and 769 rpm's good luck.
Old Aug 16, 2012 | 12:26 AM
tcarroll's Avatar
Thank you for this. Shouldnt the smaller diameter tire have more rpms?
Old Aug 16, 2012 | 08:37 AM
trucker442's Avatar
trucker442
Tire size
YEP YOU'RE RIGHT, MY BAD THE G70 14 WERE ROLLING AT 752 RPM.
Old Aug 16, 2012 | 11:03 AM
tcarroll's Avatar
I am really having a hard time with this guys. i saw my buddys 70 Cutlass S with 225/70R14s on it and I really thought it looked like to much tire and not enough space in the wheel well. It is really just the look I guess. I want to buy redlines and they are expensive so dont want to regret my purchase. I think i would like the look of the 215/70R14s but 90% of postings are saying that the 225 is the right conversion size for a G70 factory tire. These are going on 1970 ssi rims. Someone help me my brain is about to explode!
Old Aug 16, 2012 | 11:13 AM
henryk8398's Avatar
Hangin' out...
What he said. Don't stress too much! 225/70/14 and be done with it.
Old Oct 8, 2012 | 09:53 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
I'm about ro buy a set for my 70 as well
Not that cheap $-140 each
Old Oct 8, 2012 | 11:46 AM
My442's Avatar
I run 245/60-14 on SS1 14x7 rims.
Old Oct 8, 2012 | 11:53 AM
About right for BFG, think Coopers are similar, and the slightly cheaper Firestone Indy 500's no longer available. I bought real cheapo Primewells (~$70?) from Firestone and put the blackwall out since I usually have my 15" rims on the car. Over $200 for Polyglas repops if originality is important.
Old Oct 8, 2012 | 12:07 PM
Olds Specialist LOL
Looks nice have a side view?
LQUOTE=My442;462890]I run 245/60-14 on SS1 14x7 rims.[/QUOTE]
ttg
Wheels and Tires
27
Oct 31, 2020 06:54 AM
m455sx
Dec 17, 2013 07:04 PM
TenMidgets
Nov 12, 2012 09:45 AM
TRW
Oct 13, 2010 09:27 AM
ttg
Sep 14, 2008 03:15 PM
