Click Here
Proper Tire Pressure
Old Feb 7, 2012 | 03:20 PM
rmoths's Avatar
I bought a 1972 Cutlass convertible, It came with 215-65-15 Firestone Indy 500 Firehawk tires. Well I took them off to clean up the wheels and rotate.
Well I checked the tire pressure and they all had 42 lbs of pressure in them.
That seems high to me, but I can't find on the tire the recommended tire
pressure, It just says not to inflate over 44 lbs. Well I took them down to 32 lbs, I hope that's OK. Does anyone know if 42 could be right. Thanks Barb.
Old Feb 8, 2012 | 06:59 AM
1970cs's Avatar
Lansing built
tire press
Most tire manufacturers recomend whats on the factory tag, I think your fine with what you have them set at, maybe touch more would not be out of the question! p215-65-15
Regards, Pat
Old Feb 8, 2012 | 08:29 AM
You cannot use the factory tag, as produced above because the tires listed on there are for bias-plys. I would air the tires on your car to 35-38 lbs.
When you checked the tires at 42, were they hot after a drive, or first thing in the morning cold? A hot tire can read 5-6 lbs higher than a cold tire!
Old Feb 8, 2012 | 08:37 AM
Lady72nRob71's Avatar
35 cold has been my rule for radials in use.
For long term storage, 40 is fine to reduce flat spots.
Old Feb 8, 2012 | 08:38 AM
rmoths's Avatar
Wink
Thanks for the reply, It was kind of a stupid question. Everyone on this site is so nice and helpful. I'm just puzzled why they all had exactly 42lbs in them.
OK, I'll go with 32 to 35 and thanks again for taking the time to answer my question. Barb. PS. They were cold, but the high pressure in storage ( avoid flat spots ) could be why. Very good thinking. Thanks Barb.
Old Feb 8, 2012 | 09:03 AM
lshlsh2's Avatar
71 cutlass convertible
Have the same style tires(mine 14 in), I run at 40psi and never had a problem.
Larry
foreverolds
Dec 1, 2012 07:07 PM
costpenn
Apr 4, 2012 07:23 AM
Baugher Garage
Wheels and Tires
Oct 3, 2011 07:19 AM
Doug69Cutlass
Apr 6, 2009 06:54 PM
Satellitecentral
Nov 6, 2008 10:52 AM
