Click Here
One more project completed...
Old Jan 1, 2019 | 09:15 AM
72455's Avatar
1972 U code Supreme
Good day to all ye Oldsmobilers and Happy New Year to everyone!
It's a warm (but windy) day here in SE VA so I took advantage of the opportunity to finish my spare tire/jack project. I'm happy with the results and thanks to all who lended their advice and help😀
Here a few pics:
Old Jan 1, 2019 | 09:36 AM
RetroRanger's Avatar
72 Olds CS
Looks great....now about that rear bumper
Old Jan 1, 2019 | 09:43 AM
72455's Avatar
1972 U code Supreme
Thamks...and yup, the bumper is next. Got the fillers and the hardware yesterday, and I'll be rolling with that soon😀
Old Jan 1, 2019 | 12:19 PM
v8al's Avatar
Registered Olds Owner
Don't know if you moved it to the correct location or not. But the bottom of the jack is supposed to be wedged against this brace that's along the side of the trunk floor.
See picture below. This is added protection to prevent the jack from dinging the quarter panel.
Old Jan 1, 2019 | 01:08 PM
72455's Avatar
1972 U code Supreme
Thanks...I'll fix that asap.
Old Jan 1, 2019 | 03:28 PM
CRUZN 66's Avatar
Olds Fever
Nice clean looking job... Isn't it great when you can check something off your to do list???
Old Jan 1, 2019 | 04:51 PM
72455's Avatar
1972 U code Supreme
Originally Posted by CRUZN 66
Nice clean looking job... Isn't great when you can check something off your to do list???
You got that right😀. And thanks
Old Jan 1, 2019 | 05:14 PM
Nice
Old Jan 1, 2019 | 05:49 PM
Dave,
Nice job overall. One more thing - see the attached picture and suggested change. Those holes in the hook are there for that reason.
Old Jan 1, 2019 | 07:44 PM
Dave- I don't see a trunk light/lamp?
Old Jan 1, 2019 | 08:05 PM
76olds's Avatar
Hookers under Hood
Nice job !
Old Jan 1, 2019 | 08:37 PM
72455's Avatar
1972 U code Supreme
Originally Posted by Allan R
Dave,
Thanks for the tip Allan...I will take care of that tomorrow.
Old Jan 1, 2019 | 08:40 PM
72455's Avatar
1972 U code Supreme
Ya know Chief, that has crossed my mind more than once. Since you mentioned it, where exactly does it go?
Old Jan 2, 2019 | 04:38 AM
Driver's side location. I believe this is a period/model correct trunk lamp - I haven't validated. Others may comment whether this is the correct lamp. A portion of the plastic was broken on mine when I purchased it & it wasn't working; but, it didn't take long to address the issue. I've found new ones available on sale on-line. I'll see if I can find a link for you. You should have a single orange wire protruding from the wire loom at this location. The single orange wire makes the connection - ground (to complete the circuit) is established via the lamp socket to the trunk lid/frame.
Old Jan 2, 2019 | 04:46 AM
Here are a couple links. Don't buy it from OPGI for $80.00. This lamp/socket isn't worth more than $10.00. Do a little research maybe you'll find better prices.
https://www.ebay.com/itm/1969-72-GTO...IAAOSwepZaoY6x
https://www.ebay.com/itm/1970-1972-O...-/152962695187
Old Jan 2, 2019 | 04:59 AM
72455's Avatar
1972 U code Supreme
Thanks for the info...😀
Old Jan 2, 2019 | 07:14 AM
The wiring for the trunk lamp is already there from the factory. It's an orange pigtail usually tucked out of sight up by the left trunk hinge assembly. The extra piece in those ebay ads is for attaching the light to the convertible trunk. Not used on coupes.
Old Jan 2, 2019 | 09:44 AM
72455's Avatar
1972 U code Supreme
Thanks Allan...how is the the light activated? Also, in one of Chief's pics, I noticed what looks like a plug in the trunk lid. Am I missing those, and if so, are they readily available aftermarket?
Old Jan 2, 2019 | 11:40 AM
The light is activated by spring pressure on the lever. Here's what the one in my car looks like. You can see where the lamp is clipped to the side of the torsion rod mount. Movement of the deck lid hinges move that U shaped rod to turn the light on / off. The orange wire from the rear harness has the required spade connector to attach it to the light housing.
Old Jan 2, 2019 | 01:17 PM
There are no plugs in my trunk lid. There are stock holes, but there are no plugs.
Old Jan 2, 2019 | 01:31 PM
"...what looks like a plug in the trunk lid..."
...is actually a hole (I've outlined it in the picture, below). I think what you're seeing which makes it appear as a plug is shadowing from overhead lighting. If you zoom in on the picture it will provide more detail.
Old Jan 2, 2019 | 05:04 PM
72455's Avatar
1972 U code Supreme
Dave,
I made the adjustment for the jack post to sit against the brace, but when I adjusted the hook for the rod to slide through the hole, the tire sits on the hook and the rod isn't long enough to thread on the hold down nut. Rather than backtracking, I found a way to make it work. Everything is buttoned down tight, and although the rod isn't going through the hole, at least the post is sitting tight against the brace, and that's most important.
Old Jan 2, 2019 | 05:07 PM
72455's Avatar
1972 U code Supreme
Lol...after closer inspection of your pic, I see the light...or should I say "dark" (as in dark hole).
Thanks for clearing that up Chief😀
Old Jan 2, 2019 | 05:08 PM
There are two different length rods available. You have the same wheels as myself. When I purchased my car, the spare wheel, jack, stand, hook & lift pad were laying in the trunk - pretty sure someone didn't realize they had the wrong size (short) rod and needed the long rod. I purchased the longer rod - problem solved.
Old Jan 2, 2019 | 05:13 PM
Inline Oldsmobile Catalog p. 148
Old Jan 2, 2019 | 05:55 PM
The delta between the shorter (6.5") & the longer (8.50") = 1.25" - the length you'll gain if you currently use the shorter rod.
Old Jan 2, 2019 | 08:13 PM
72455's Avatar
1972 U code Supreme
Yep...I have the longer version that Nick sent with the jack when I bought it, so I'm gonna clean it up and use it.
Old Jan 3, 2019 | 04:13 AM
EDIT: Correcting my math! "The delta between the shorter (7.25") & the longer (8.50") = 1.25" - the length you'll gain if you currently use the shorter rod." My bad.
Old Jan 3, 2019 | 05:56 PM
72455's Avatar
1972 U code Supreme
A little spit and polish and it shined up pretty good...
Old Jan 3, 2019 | 06:14 PM
72455's Avatar
1972 U code Supreme
Just went out and took a quick peek...found the wire. It was actually bundled in with the harness. Gonna order the light tomorrow...stay tuned for an update 😀
Old Jan 4, 2019 | 06:51 AM
  #31
It's a 30 second install Dave. Not much to do except clip it in place and connect the wire. Use the little bosses above the torsion bar slots to set it in place. Perfect fit.
Old Jan 4, 2019 | 07:59 AM
  #32
72455's Avatar
1972 U code Supreme
Thanks Allan...I'm looking forward to getting it done.
Old Jan 4, 2019 | 10:08 AM
  #33
Gotta make sure the metal clips make good contact to the torsion bar mount metal as that is how it is electrically grounded.
Old Jan 7, 2019 | 05:07 PM
  #34
72455's Avatar
1972 U code Supreme
So I tried the longer rod through the hole and it didn't work. Because of the tire sitting on the hook and the tire being wobbly using this setup, I tried to get everything tightened up. No bueno...the hold down rod pulled itself straight and everything was still loose, so I scrapped that idea and went back to how I had it. Everything is all nice n tight, and I got the rubber disc put on, so I'm done.
Thanks again to all who helped.
Dave
Old Jan 15, 2019 | 10:26 AM
  #35
Dave I don't know if you got your trunk light yet, but I was digging through some old e files and found these. Maybe they could be of use to you.
Old Jan 15, 2019 | 10:47 AM
  #36
This is not correct. The actual installation takes 17.50 seconds - 30 seconds maybe if the trunk is not already open.
Old Jan 15, 2019 | 10:50 AM
  #37
But if done at a dealership, it's a 15 minute flat rate job, and including shop supplies, dealership premiums and taxes costs $87.42
Old Jan 15, 2019 | 10:53 AM
  #38
Indeed, indeed.
Old Jan 15, 2019 | 02:42 PM
  #39
72455's Avatar
1972 U code Supreme
Thanks Allan...I got my light but haven't installed it yet...will be doing it tomorrow 😀
Wheels and Tires
34
Jan 1, 2019 06:01 AM
Zr1bandit
Aug 19, 2018 10:47 AM
tv442
May 28, 2018 09:15 AM
Jersey Jeff
Apr 24, 2018 04:27 PM
OldsMotion
Oct 10, 2009 10:17 PM
