How did I round out my SSI lug holes?
I have a set of original 14x7 SSIs that have made the rounds on several of my cars since 2003. The lug holes passed the "dime test" when I refinished them at the time and have been fine for years.
I put them on my W-31 when I bought it last fall and earlier this year I started getting a clunk up front after a couple short drives. I thought it was a suspension issue since I hadn't done a shakedown on the car yet so I parked it. I swapped the SSIs back to my SX and right away I heard clunking from all sides. I pulled the drivers side front wheel and four out of five lug holes were almost big enough to drop a nickel through, let alone a dime. I know at least one other wheel is screwed up too since I put an SSII on tonight and went for a drive up the street and still heard clunking.
So what the heck could have happened? Loose lugs? Over tightened? Wrong capped lug nuts? Never had this issue with them before. I haven't found any other threads anywhere on this issue even though I've heard for years that this is an issue with SSIs.
Thanks for any insight. I have another nice set of SSIs on the shelf and don't want to trash them too.
Terry
Terry
I know that the angle of the nut (and the wheel seating area, I think?), the "V" was changed by GM at some point. Capped Olds early (67-74?...more?) lug nuts have a wider "V". I don't know what angle the aftermarket like Gorilla uses. Repros have the right angle. It's probably your nuts!
Steve Orr is making lugnut seats that will repair the seats in original wheels.
http://www.oldschoolplating.com/lug-seats-2.html
Has anyone on here tried these yet?
Thanks.
Call and talk to Steve, he is a great car guy. I use him for all of my re-plating.
I have not used his seat repair kit, but I do know that they have been used on a few high end LS-6 and early production L-78 Chevelles during restoration to retain their original wheels.
Terry
Terry
I brought up this very topic several years ago. Check out this link: https://classicoldsmobile.com/forums...bulletins.html
Mike
The parts place sells these lug nuts. I think these are designed to correct the problem with the holes.
WT12467Z - (1964 - 1977 Cutlass/442) OVERSIZED LUG NUTS - SET OF 20 (SIMILAR TO ORIGINAL ACORN LUG NUTS BUT THESE HAVE AN OVERSIZED FLANGE FOR USE WHEN THE WHEEL AREA HAS BEEN WADDLED OUT) $49.00
Terry
I thought the correct term was "wollered" out?!?!
I've been thinking about putting the stock SS1 wheels back on the 72 I bought a few months ago. I can check the holes visually when I get home, but how can I be sure they won't have this issue later? Is there anything else I should check for besides the obvious on these? They had been in a garage for who knows how long, at least since mid nineties when I bought the car.
edited to add: I didn't buy the car in the mid nineties, I think the wheels have been sitting around since then.
Last edited by jeff in colorado; July 31st, 2014 at 05:34 AM. Reason: clarification
Just saw this thread.
Actually, I think the correct term is "wallowed",
but, in West Virginia, it IS "wollered out".
Any updates on the availability of the "fixes" previously mentioned?
I've got a couple of nice sets of SSI's that need help, too.
I'd swear I had posted a pic of the acorn lug nuts I bought at NAPA that were one size up (7/16") - they look fairly correct but are maybe 3/8" longer. They solved the problem completely for me - I ran those same SSIs with no problems the rest of the summer.
In any case, this is what I used and they worked great (in the middle of the pic, with a stock SSI acorn below it). I bought the Parts Place lug nuts (shown at the top in the pic) and they were NOT correct looking for SSIs.
Terry
Terry
Terry
Terry
I HAVE a couple of sets of those lug nuts.
I bought them because they looked close to the originals.
I didn't really look closely at the mating surface until now, but,
your right, I think they will fix my problem.
I had this same problem, and it was a mixture of wrong lug nuts, which i got the ones posted above. but is more so caused from improper tightening. I found that if you do not do the 3 stages of tightening it can cause them to set wrong
oldzy
Suspension & Handling
December 5th, 2010 09:49 PM
