Gentlemen. When I take a look at 15x 7 SS II wheels how do I tell if the Wheel is set up for snap on hubs versus bolt on. Believe the wheels came off a Cutlass. Rookie question to be sure but it’s part of the learning experience.
Bolt on center cap wheels have a hole on the inner area of each of the “spokes” where the cap bolts go through the wheel.
Snap on center cap wheels do not have the 5 holes, and have a center “snout” with 5 square notches around the inner perimeter where the cap clips insert into the end of the snout.
I'll also take this opportunity to note that the side-by-side photo makes it very easy to see the difference between 14" and 15" SuperStock II/III wheels. No, this has nothing to do with snap in vs bolt in.
Joe, again thank you for your contributions to my continuing questions about all things Oldsmobile. You make my time on this site
incredibly productive.
