Correct Color of SSII wheels - 1970 442 convertible
Hi. I'm researching the correct color for SSII N66 wheels for my car (see photo). The Factory Assembly Manual states:
"N66 WHEELS ARE TO BE PAINTED DARK
GRAY LOW GLOSS ENAMEL CODE #372
IN AREAS SHOWN. (SEE FIG. 3)"
However, the Manual goes on to say"
"FOR CARS ORDERED WITH SPECIAL ORDER COLORS AND EOUIPPED WITH
HUB CAPS WHEELS ARE TO BE PAINTED IN LOWER BODY SPECIAL ORDER
LACOUER."
I have a special order color car, Rallye Red. I know in 1971, the SSII wheels were frequently painted to match the body color, but I can't say I've seen any in 1970 looking this way. Though the Factory Manual may suggest this?
Also, there is a set of 15" rims advertised as off a 1969 for sale online. See photo. I think that factory 15" only came on the 1969 Hurst/Olds.... I am wondering if they will work on my 1970??
Any SSII suppliers you can recommend...I'm looking at 15" aftermarkets perhaps.
Thanks!
LACOUER."
Thanks!
Poverty Hub Caps maybe?
Hmmmm....after seeing another post, I realize there is a poverty hub cap option...seems like the wheel in that case is painted to match the body color for that rim option, so I'm now thinking gray is still the correct color for the SSII for my special order paint.
Well, you're certainly not the first to ask this question. Have a look at the following threads, it may help you without having to go around the bush too much. This should get you started. You might have to go through several of the permalinks on each thread to find all the info you're looking for, but it's there. Good luck with your project. FWIW, I decided I wanted my wheels to match the body color. I think it looks pretty good, but then again my car is silver. I'm sure however you decide it will dramatically change the look of your car back to factory.
https://classicoldsmobile.com/forums...ms-colors.html
https://classicoldsmobile.com/forums...s-70-72-a.html
https://classicoldsmobile.com/forums...eel-color.html
https://classicoldsmobile.com/forums...ey-wheels.html
And yes, the quote from the assembly manual refers to the plain steel wheels with dog dish hubcaps, NOT to the SSII wheels.
They are not FWD and they are not 15" either. The seller measured the outside diameter. The 14" or 15" dimension refers to the size of the hole in the tire, NOT to the outer diameter of the wheel, since the lips of the wheel need to extend beyond the hole in the tire to retain the tire. The correct measurement is across the bead seating surface on the wheel.
They should have 15x7jj stamped on them if 15" or 14x7 if 14", and of course 14x6jj if the correct '69 SSII. Joe, do you see what I mean by the whole center section appearing to be raised? Just don't look right. I have all of the above mentioned sizes, and none look like them.
RAMBOW
December 7th, 2017 08:22 PM
classic997
May 28th, 2015 02:36 PM
