Click Here
circle racing ssii olds wheels
Old Jan 30, 2020 | 12:36 PM
tt455's Avatar
https://www.ebay.com/itm/oldsmobile-...8/113994516462
I found these on ebay, not sure if anyone has seen them yet. They look nice the black throws it off but if you paint the inner wheel argent gray may look very close. They have 15x7, 15x8, and 15x10.
Old Jan 30, 2020 | 02:11 PM
Not a bad looking wheel if its straight and balances.
Old Jan 30, 2020 | 02:33 PM
deadeyejedi's Avatar
nice looking wheel .The ad states "must be lug centric balanced" Is this the case with factory olds wheels ? Back forty years ago in auto mechanics class our tire balancer just had the cone style hold down.I wonder how many tire shops know the difference
Old Jan 30, 2020 | 02:42 PM
I think it is for the snap-on style SSIII wheels, whereas the bolt-on style SSII wheels are hub centric.
Old Jan 30, 2020 | 06:57 PM
Yes, this is the case for all SSII/III wheels with snap-in centers. There is no controlled pilot hole in the center that can be used to center the wheel on a normal balancer cone.
Old Jan 30, 2020 | 07:48 PM
RetroRanger's Avatar
72 Olds CS
I think the real news here is they want $619 for Two of them....
thats 1200 for four
$1500 of a set of five
Old Jan 30, 2020 | 08:17 PM
thats 1200 for four
And you still need caps and lugs.
Old Jan 31, 2020 | 05:49 AM
Funkwagon455's Avatar
Don't forget the tires!!!!!
Old Jan 31, 2020 | 06:26 AM
thats 1200 for four
Have you priced getting an original wheel replated? Makes this look like a bargain.
Old Jan 31, 2020 | 11:54 AM
VERY INTERESTING!!! This may explain why it was so hard to get the new BFG tires balanced on my OEM SSIII wheels. This was about 7-8 years ago. The shop would balance them and I still noticed a shake- they said the wheels must be bent- which I knew they weren't. They ended up balancing ok, but I'll just bet they were balanced using the balancer cone. But you know... now that I am thinking about it, I worked at a Montgomery Wards auto center at the Lansing Mall back in the early 80's and we must have balanced 100's if not 1000's of Olds SS wheels and I know we always used the cones. So I dunno....
Old Jan 31, 2020 | 12:32 PM
The fact that a shop used a cone to balance the snap in wheels doesn't make it right. Just look at the backside of the wheel. There is no controlled, concentric surface that provides a locating surface for the cone. Bolt-in wheels have a pilot bore that is formed. Snap in wheels do not.
Old Feb 1, 2020 | 10:39 AM
Joe is right, and the real issue is not that going hub centric on an SSII won't work, it's that it will work, just poorly. What I mean is you can get closer to balanced than an unbalanced wheel doing that....or you could get worse.
Hell I had a Toyota dealer 'unbalance' Toyota rims by making them worse than they were without weights due to them being dumb.
Old Feb 2, 2020 | 12:44 PM
Yep that makes sense! Funny how sometimes things are just done- no thought to it just always been done that way so that how it is....I learned something today!
fasteddy
Wheels and Tires
136
Mar 11, 2026 02:35 PM
svnt442
Feb 17, 2017 05:59 AM
DoubleV
Wheels and Tires
Apr 9, 2014 02:41 PM
randomarrival
May 2, 2013 08:51 PM
TheMysteriousX
Jan 22, 2010 04:30 PM
