Click Here
67 Delmont wheels
Old Jan 15, 2013 | 06:27 AM
67DELMONT88's Avatar
67 Delmont wheels
Hey Guys,
I would like to change my wheels to 18x8" with 235/55R 18" tires from the factory 14" size wheels unless they wouldn't fit. I think I will need to use 1" spacers with the 18x8 4 1/2" backspace wheels.
Does anyone know the hub diameter right off hand?
Where could I get hub-centric spacers?
The hub diameter on the 18" wheels is 83.82mm.
I have the factory rear still in the car as far as I can tell, it's a 10bolt BOP Pontiac style.
I would also like to change to Rear Disc Brake from Drum if anyone knows of a kit or components that will fit.
Thanks for any help/advice on these issues.
Old Jan 15, 2013 | 06:47 AM
copper128's Avatar
Lt. Buzzkill (ret.)
I don't see any reason why 18x8's w/4.5 backspace wouldn't fit without spacers. The wheel wells are pretty big on these cars.
I would say that you're likely to get a rub on the inside of the front when turning. You probably have to use a spacer and/or limiters in front.
Is your car a Delmont 330 or 425? The 330 cars do use the BOP 8.2" 10-bolt rear but 425 cars use the big Pontiac 8-7/8" 10-bolt cover, 12-bolt ring gear. Sorry I don't know the hub diameter. BTW, those big rear drums work pretty well with good shoes and proper adjustment. I don't know that you'd see much of an improvement with a rear disc conversion - assuming you have discs on the front now. An easy way to get more rear brake is to swap on the 1/2" wider rear drum assemblies from a 98. You'd need the whole brake assembly including the backing plates.
Old Jan 15, 2013 | 09:15 AM
Well, since you're buying new wheels, get ones with correct backspacing so you don't need spacers. And as above, 8" wide wheels with 4.5" BS shouldn't need spacers - that's about as close to zero offset as possible. The tire diameter and section width will determine clearance.
Old Jan 15, 2013 | 03:07 PM
Thanks for the info guys.
The car is a 330cid. I am adding front disc to the car.
The reason I was looking at using wheel spacers is I haven't had any luck finding 18x8 wheels with the offset I would like to move the wheels out in the wheel well. I believe there is room for it. I could have custom wheels made for around $500 each.
Also be nice to find a good used limited slip for it.
My442
Dec 26, 2017 05:08 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
WTony
Jan 15, 2011 07:53 PM
Stephen
Sep 14, 2004 09:43 PM
