Click Here
65 delta wheels
Old Sep 16, 2012 | 10:07 AM
Jeda88's Avatar
65 delta wheels
Looking for some help on new rims and tires size for my 65 Delta 88. I'm looking at the cragar chrome keystone klassic rims at summit racing. I would like to go as wide as possible and want to give it a little rake look with the rear a little higher than the front. The web site list several bolt patterns,backspace and offsets. Thanks for any help.
Old Sep 16, 2012 | 02:40 PM
Your bolt pattern is 5 x 5". You want as close to zero OFFSET as possible. I prefer specifying offset instead of backspacing because backspacing is a function of wheel width, offset is absolute. For zero offset, the backspacing is a little over half the width - 3.75" BS on a 7" wide rim, 4.25" BS on an 8" rim, etc.
Old Sep 17, 2012 | 07:46 PM
Jeda88's Avatar
Thanks now I understand the backspace. Sounds like I need to stay either with the 7 or 8 inch width rims. Way about and can I convert to front disc brakes in the future?
Old Sep 17, 2012 | 09:06 PM
Unless you are buying 1960s vintage drum brake-only wheels, any wheel you can buy today will clear factory-size disk brakes. Of course, if you are using an aftermarket kit, it depends on the size of the rotors and calipers.
Old Oct 24, 2012 | 10:44 AM
Jeda88's Avatar
Ok I have some more info on the two types of rims I would like to go will from Summit both are the Cragars Keystone klassic and the cragars ss supersports.
the keystones are 5x5 8 inch with a 3 and 7/8 back space the 10 inch are 4 and 1/8 back space.
the ss supersports are 5x5 8 inch with a 4 and 1/8 backspace and 10 inch are 4 and 3/4 back space.
I would like to go as wide as I can. any ideas on tire sizes and combinations? Thanks
My442
Dec 26, 2017 05:08 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
WTony
Jan 15, 2011 07:53 PM
DAN76
Oct 7, 2008 02:31 PM
Kennybill
Oct 3, 2006 05:37 PM
