Click Here
245/60/15's on front + 1" lowering springs... rubbing?
Old Nov 22, 2011 | 08:40 PM
oldzy's Avatar
Just wondering if anyone is running ~1" lowering springs (I have Hotchkis 1" lowering springs) with 245/60/15 BFG Radial T/A's tires up front, and if so, any rubbing issues?
Old Nov 22, 2011 | 10:53 PM
Mr Shifty Sidney's Avatar
I am running the 15 X 7 repo SSI's with 245/60/15 WITH STOCK springs on a 70 Cutlass conv. with no problems.
Old Nov 23, 2011 | 02:42 AM
OldsManNJ's Avatar
1971 Cutlass S
I have 245 60/15 on the front of mine without it being lowered. I have no clearance issues either. 275 50/16's on back - also do not hit.
Old Nov 23, 2011 | 02:58 AM
ziff396's Avatar
I am running 255/60/15 on re pop ss1's (7") with 1" lowering springs. The only time they rub is when the wheels are cranked and you go over a bump. Other than that, they are fine.
Old Nov 23, 2011 | 04:37 AM
RetroRanger's Avatar
72 Olds CS
Plus 1
same tire size and rim but my springs appear to be original and needing replacement shocks are new just rubs at full lock w a bigger bump in the road
Old Nov 23, 2011 | 01:57 PM
Indy_68_S's Avatar
Originally Posted by OldsManNJ
I have 245 60/15 on the front of mine without it being lowered. I have no clearance issues either. ...
I ran 245 60/15 on the front (& 275 60/15s on back) with really beat down orig springs with no issues....
Old Nov 23, 2011 | 02:43 PM
allyolds68's Avatar
I run an oversize sway bar with no lowering & mine rub
Old Nov 23, 2011 | 04:37 PM
ziff396's Avatar
I also am running an 1 1/4" sway bar.
pogo69
Mar 31, 2014 05:01 PM
ziff396
Mar 9, 2013 06:54 AM
oldzy
Suspension & Handling
Jan 6, 2012 06:31 AM
boese1978
Dec 11, 2011 11:22 AM
