Click Here
235-60-14
Old May 10, 2019 | 09:39 AM
Blackpage's Avatar
235-60-14
Gentlemen,
Trying to visualize 1971 chrome SS1s with these tires. Anybody have this combination & willing to post a picture or two ? I’d appreciate it.
Old May 10, 2019 | 10:46 AM
1970F85W31's Avatar
If your question is in regard to 68 -72 model years for a Cutlass/F85/442, consider the P245/60/14. That is equivalent to a G60-14 and is the size the 1972 HURST OLDS used. It will fit easily without rubbing and look good on a 7" wide wheel. The 235 section width and associated sidewall height is too small.
Old May 10, 2019 | 11:12 AM
Agreed, 235-60 has a very short sidewall.
Old May 10, 2019 | 02:19 PM
The commonly-available tires closest to the original ones for your car are the BFG 225/70-14s. These are about 26.5" in diameter. The 235/60-14s are a Honda-sized 25" in diameter and pretty much disappear in the A-body wheel wells. Keep in mind that the 235s are a whole 10mm (7/16") wider than the 225s. Even the 245/60-14s are only 25.5" in diameter and still only about 3/4" wider than the 225s. If you are stuck with 14" tires, get the 225/70s or pay for the repro tires from Coker. The 60-series are just too small in diameter.
Old May 10, 2019 | 04:00 PM
Blackpage's Avatar
Thank you for the advise gentlemen.
Old May 17, 2019 | 11:14 AM
1970F85W31's Avatar
1972 HURST OLDS Brochure
OP, please view the attached brochure. The P245/60/14 (G60-14) size looks great on the vehicle! What did you decide to do?
File Type: pdf
Old May 17, 2019 | 11:53 AM
droptopron's Avatar
delete
With the rounded edges of a radial it doesn't look nearly as meaty. I had 235/60-14 on a 70 convertible and it didn't fill up the wheel well
Old May 17, 2019 | 12:03 PM
lemoldsnut's Avatar
I have the 235/60SR14 on my 67 442 on 70-72 Rally 1 14 x 7 wheels. THey are too short. Look okay but too short. Will go with 235 70 sr 15 next time. Or even a 17" wheel.
Old May 17, 2019 | 12:20 PM
1970F85W31's Avatar
Your issue was that the tire section width was wanting, and the corresponding sidewall was therefore too short. That is why the wheel well had a gap. The OEM 1972 Hurst Olds tire IS a radial. Look at original stock photos of the car, looks great! Why run a 225/70 when that width is only 1cm wider than that used on a Toyota Prius? Now THAT doesn't fill the wheel well...
Old May 17, 2019 | 01:05 PM
droptopron's Avatar
delete
No, the issue was it was too short. A 235/60-14 is 25" tall as compared to 26.5" for a 225/70. The stock G70-14 is 26.8". Almost 2" is too much to go down IMO
Old May 17, 2019 | 01:24 PM
245-60-14s rear view. Don't worry about the bald tires, they have since been replaced by a set of 15x7 wheels and 245-60-15 tires. They lived a good life and had lots of fun doing smoky, sideways burnouts before they were retired to use as axle stands.
Same tires (245-60-14) side view. The rear of the car is a bit high due to the springs, but you can see how even on the front the shorter 235-60 would really look too short.
Old May 18, 2019 | 07:32 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
This is 205/70R14 front and 225/70R14 rear
This is a 235/60R14 on a 14×6 rim on my 70S.
205/75R14 front and 235/60R14 rear.
Old May 18, 2019 | 08:36 AM
1970F85W31's Avatar
Your initial reply quoted my comment in regard to the OP considering 245/60/14s. The size I mentioned was stock by HURST, and also being a radial with what you referred to as a "rounded shoulder which doesn't look as meaty". Your 235 size was indeed too short, and I'm not a proponent of those way under size tires. Also consider that most vehicles after half a century in existence will have had maintenance that you are not privy to at all. That may have included spring replacement with an incorrect rate/free height which changed the ride height, or the chassis will certainly have lowered because of spring sagging by now. Lastly, it is noted in the 1970 442 W30 original, new product, road test by magazines "Speed and Supercar" and "CARS" that the G70-14s contact the fenders during hard cornering and the tires were described at that time as being "too tall".
Old May 18, 2019 | 08:38 AM
1970F85W31's Avatar
Those sizes look perfect, very 1972 HURST Oldish!
Old May 18, 2019 | 08:48 AM
Blackpage's Avatar
Thanks Gentlemen,
Doesn't matter at this point. My hemming & hawing made me late in purchasing. The guy sold the tires.
Old May 18, 2019 | 09:01 AM
1970F85W31's Avatar
Originally Posted by Blackpage
Thanks Gentlemen,
Isn't it great to be a part of a group so passionate about cars, Oldsmobiles in particular? My "Those sizes look perfect, very 1972 HURST Oldish!" were in regard to Fun71's convertible.
Old May 18, 2019 | 04:15 PM
hurst68olds's Avatar
the OEM 1972 Hurst/Olds tire is NOT a radial
Goodyear POLYGLAS = polyester cord w/fiberglass belts
Goodyear POLYSTEEL = polyester cord w/steel belts
the Polysteel tire had same appearance (square shoulder) & tread as Polyglas - 1973 Hurst/Olds was the first with a radial tire
Old May 18, 2019 | 10:01 PM
exotec's Avatar
Olds Omega
Thinking of the same setup 235/60R14 on 14x6 for my Omega which was original E78-14
but BFG say the rims should be at least 6.5 width. Will this be an issue?
Sorry for jumping in with my question in that topic!
Old May 19, 2019 | 05:15 PM
I ran 245/60R14 on the same 14×6 rim. Had 0 issues and spun the **** out of them.
Old May 21, 2019 | 07:39 AM
exotec's Avatar
Olds Omega
Than lets go! Thankx
Old Aug 3, 2020 | 08:20 PM
Brittany Wolf's Avatar
245 60r14
Darkalley
Wheels and Tires
Jul 25, 2019 02:55 AM
Levellord
Wheels and Tires
May 31, 2017 08:52 AM
electraman87
Aug 10, 2014 11:36 AM
miko442
Wheels and Tires
Jan 11, 2013 03:47 PM
scrappie
Wheels and Tires
Jul 30, 2010 06:02 PM
