Click Here
Are 205/70R14 too narrow for 14x6 rims?
Old Jan 23, 2016 | 02:14 PM
72Blazerod's Avatar
Hi Guys,
I want to hear your opinions about tire choice. I can get a pretty good deal on some 205/70R14 redline radial tires (they were on a '65 Mustang). I want to put them on some 14x6 wheels and then onto my 1972 Cutlass Supreme. Would those tires look too skinny? What was the stock size tires back in '72? Let me know what you think.
Old Jan 23, 2016 | 04:03 PM
They should mount on those wheels with no problem, but the diameter is too small to look good on your '72, 225/70r14 are better for filling the wheel wells.
Old Jan 23, 2016 | 04:24 PM
1970cs's Avatar
Lansing built
Skinny is not the issue but you are losing 1" plus on the proper rolling diameter! Speedo will be off.
A 70 series tire no matter what your first number is, the sidewall will be 70% of the tread width.
Pat
Old Jan 23, 2016 | 04:45 PM
205 mm is just over 8" section width. You could use a 7" wide rim with no issues. The 205/70-14 is only about 25.3" in diameter and as others point out, way too small for a 1972 A-body. There will be a lot of daylight between the tire and the wheel opening. The suggested 225/70-14 is over an inch taller. If you want to stay with the 205 section width, then a 205/75-14 would be a better choice (and nearly the same OD as the 225/70-14).
LJA72
Jan 31, 2014 08:02 PM
ratterberry
Jan 11, 2012 01:10 PM
CutlassLegend
Care and Appearance
Aug 6, 2011 11:08 PM
henryk8398
Feb 22, 2010 08:54 AM
67cutlass442
Jul 7, 2009 10:59 AM
