Click Here
1970 Oldsmobile cutlass Rallye 350
Old Oct 19, 2019 | 09:02 PM
Hondo's Avatar
Hey everyone, question how wide of a tire can I put on the stock rims. When I get this car out I want to be able to get fatter tires in the back. I think it would look good
Old Oct 20, 2019 | 06:36 AM
The stock wheels on your Rallye are only 14x7. That severely limits tire selection. The two most popular options are 225/70-14 or 245/60-14. The 225/70s are about as close to the original tires in size as possible, at 26.4" outside diameter and 8.9" section width. The 245/60s are 9.6" section width but are a Honda-sized 25.5" in diameter. A lot of people run them on 14" SSII wheels, but personally I think they leave waaaay too much daylight in the wheel wells for only 3/4" more width.
Old Oct 20, 2019 | 07:05 AM
Read this thread
https://classicoldsmobile.com/forums...-yours-105914/
Old Oct 20, 2019 | 10:07 AM
Hondo's Avatar
Thumbs up Joe Padavano,
Grazie, Thank You. I was scared you were going to tell me, to go a page on CSM book. I dodged that bullet..
I use to have fatter wheels on mine when I was 18, I think they were 60's or 50's
No Seriously THANK YOU..
Old Oct 20, 2019 | 10:11 AM
Hondo's Avatar
Thumbs up Old Cutlass
Thank you no I can actually see what they look like... NICEEEEEEEEE
Old Oct 20, 2019 | 10:18 AM
Yeah, unfortunately tire makers don't make a lot of 14" tires anymore. If you want to spend big bucks, you can get repros of those older tires from Coker. For example, they sell a 265/50-14 tire that is 11.5" wide but only 24.5" in diameter. That's waaaaay too small for the rear wheel wells on an A-body - that's 2" smaller in diameter than OEM. But at least they are only $300 each.
Coker also sells repro Firestone Wide Oval bias ply tires, but again, the largest is a G70-14, which is virtually identical in size to the 225/70-14s I mentioned before.
RALLYE KID
Mar 5, 2015 09:28 AM
RALLYE KID
Mar 5, 2015 09:25 AM
1970cs
Nov 17, 2013 07:03 PM
Junkman
Feb 10, 2012 11:25 AM
